I use 8 roller shutter actors (liuminize (5128.10)) and have problems with the directions and with “tilt”.
Have to say, I used them for some year now as a dimming light control without problems.
Lately I updated all my stuff: Raspberry 4B, Pi-OS Bookworm, Homebridge, deCONZ and Conbee III.
In the latest deCONZ-version the devices are recognized as window-shutter-devices, which is fine!
When testing in the deCONZ GUI in Cluster-Info (Window Covering) sending “up/open” moves the shutter up and “down/close” moves it down, so I think they are wired correctly. BUT: in Phoscon → Homebridge and lastly Apple HomeKit the direction is reversed: to open I have to shut them (Siri, shut the shutters), to shut them I have to open them.
Can I simply switch directions or should I change the wires for up an down?
The Open/Close and Lift-States are also displayed wrong, but I managed to change this in state/open and state/lift (by setting Item.val= 100-attr.val) - but this doesn’t change the behavior (switched directions) when I want them to open or close.
How can I disable the tilt-function… my shutters don’t have a tilt. they’re just rolling shutters. the actor thinks, they have a tilt, which leads to a short opening (10%), when they’re fully closed … or a short closing (10%) when they’re fully opened.
thanks for your reply!
Yes, i am using the covering cluster, not the on/off.
I calibrated my actors, and as said, i used them fore some years now without any issue (exposed as dimmable light).
I tried to check the “reversed” option in the gui (window covering → attributes → mode) nothing changes. (btw, if i check “calibration mode”, the actors calibrate themselves).
I checked all the issues by AndreKoepke (your links), but there’s nothing which helped me.
At the moment i went back to the original (wrong) lift and open states, because otherwise i can’t control my shutters, as apple HomeKit “sees” they are open (which they are with “Item.val=100-attr.val”) and the “close” command would open them. so HomeKit does nothing.
Should i report a bug? Because there’s no way to reverse the shutter-motor? otherwise i will change the motor-wires as i think i get the result i want… then, just in the deconz gui (window covering cluster) the directions are wrong - i could live with that.
I m checking the code and there is no “hack” that can reverse classic request. So I don’t see how the API can use reversed command than on the GUI.
You can try direclty with the API but for me phoscon/homebridge will do same.
On manual
After pairing with a Zigbee control panel or a remote control, the shutter actuator is controlled by dimming commands: less than 30% moves “closed”, more than 70% moves “open”.
So perhaps this device is not make to work with covering cluster ?
As “fast hack”, you can try a fake DDF with mimic a dimmable light (just need to change the type and remove open/lift/titlt)
And BTW you have too the 10% reversed move with using open/close with the GUI ?
Yes, the devices worked as a light dimmer for over a year now. I recently updated deconz, homebridge and switched to homebridge-deconz (from hb-hue) and my devices suddenly were exposed as covering-devices in HomeKit. That’s where it began…
Now for testing I switched the Motor-Wires on the device and now the controls in phoscon/homebridge and HomeKit work like they should: Open moves up, close moves down. Now fully closed has the lift-state 100% in deconz. I think i read somewhere that that’s correct (100% is closed).
But confusing is that sending “up” in the GUI-Cluster does the same as setting lift-percentage to 100% (shutters move down) and “down” does the same as setting lift-percentage to 0% (shutters move up).
But that’s not bothering me, as i control it via HomeKit.
Also confusing: for HomeKit it’s closed at 0%, like “20% open” or “95% open” and 100% is fully open.
No, when sending open/close in the Gui, there’s no 10% reverse movement at all.
Here I set the tilt-percentage to 100% which leads to fully closed shutters (no reverse movement when closing the shutters) but always like 10% reverse when opening the shutters (via homekit).
DeConz first sets the lift-percentage and then the tilt. If i mange to get rid of the Tilt-Movement, i am where i want to be.
This, I can understand …
Have checked the code again and the API make the same request, perhaps third app are using the 100%/0% level instead instead of the open=true.
To be sure you can try to get log to see the request made by the application or try yourself direclty with the API Getting Started - deCONZ REST-API
So i have to correct me: When sending open/close in the Gui, there IS the short reverse movement (as it is by controlling it via the rest api) - the device sets the tilt-percentage after reaching the lift-state.
I also discovered, that 5 of my devices are “Tilt Blind - Lift and Tilt” and 3 of them are just “Rollershades” (Window Covering Type at the Attributes in Window Covering cluster). But that value is read only, so i can’t change the type. The Rollershades-types don’t apply the tilt-value, the others do.
They are ALL iluminize 5128.10 bought at the same time.
Tomorrow i try to see, if there’s any zigbee-command, which triggers the tilt-thing. And i will try if it occurs, when switching up/down with a hardware-switch on the device.
This code part is used ONLY if you have "tilt":14 for exemple, else it’s totaly ignored.
I thnik, the device sets the tilt-value to “open” (=0%) when opening the shades and “close” (=100%) when closing the shades
So can use instead the field “lift” with 1% and 99 % ?
Good question, and you have the same device with different device type, strange too.
For me there is an hardware method to change the device type, but I found nothing in documentation.
And the attribute 0x0000 is read only from zigbee specification
The devices which are “Tilt&Blind”-Types have a "tilt"state which is between 0 and 100. And whatever it is, the device moves to this tilt-value after reaching the set lift-value.
I tried, but I get a “writing failed” when changing the type (deConz Gui)
I goto in touch with iluminize to find out, why there are recognized different types and maby a way to change it. Waiting for the reply.
I got it!!
I talked to iluminize: you can change the actor from “tilt&blind” to just “roller shade” by calibrating it by pressing twice on the calibration-button.
The manual says: calibrate by pressing 4 times on the calibration button. So I did no other than pressing 4 times in the past.
Just calibrate by pressing twice did the thing!
