Hi.
New to this but I just got hold of a Vallhorn motion sensor from IKEA and tried to add it in the Phoscon app. No luck really.
It will pop up in Deconz but doesn’t seem to connect to anything. Is there any information You would need from me I’ll be glad to provide it but will need some guidance on how to obtain it.
Can you open a device request on GitHub ?
Done, hope I got it correct, let me know otherwise.
BR
Magnus
Does anyone know if the lux reading will update without motion? I’m really desperate for an outdoor brightness sensor
when will Vers. 2.25.02 released. i have a few Vallhorn and i want to use them
schade dachte hier bekommt man kurzfristig eine Info!
Please post in English as we are a English forum.
You can copy the DDF to your local DDF folder (e. g. /home/pi/.local/share/dresden-elektronik/deCONZ/devices/ikea)
and
that sould work (have not yet tested it, too lazy)
For me it doesn’t work.
But i’m also not the Linux expert…
You have to restart deCONZ after adding the files
Worked for me, both motion sensor and door sensor. Thanks to the developers for doing this so fast. Yes, had to make/copy the files in the right directory, and reboot. Before that the two sensors was “unknown” in deconz when adding. Expect i can delete the temporary DDF files when this is out of beta and new stable is available. But this is great so far. Cheapest door magnet sensor so far, and albeight it is not the smalest, it uses regular AAA batt, not some tiny button cells, so hoping for long battery lifetime. Time will shove…
73 de LA5XOA
Norway
unfortunately it doesn’t work for me either.
First I copied the files into the directory as indicated above and restarted. However, the Ikea sensors were not recognized.
Then I copied them to
/usr/share/deCONZ/devices/ikea and restarted again.
Even then, they were not recognized
Update:
I had to reconnect/rebind the sensors. After that it worked
Hello, I’m new at this and have one question… Is there a way to minimised the range of the sensor. So only moves nearby will active it ?
Hi, more than a year Vallhorn works Fine.
Now After Connecting a new Device (E27 of any other) the Lux value is freezed. Only After a restart it works again.
Anyone an idea? I‘m using the newest Beta.
I’m running deconz 2.05.72 (docker container). When logging into the server I could not find /usr/share/deconz/devices, however I found /root/.local/share/dresden-elektronik/deCONZ but also this folder did not contain a “devices” folder. Am I looking in the wrong place? I tried creating the folder under /root/.local/share/dresden-elektronik/deCONZ and copied the files in there under ikea subfolder, but even after restarting I was not able to add the devices.
