Posted this incorrectly as a bug and they kindly sent me here. Can anyone offer any help. This button worked great for over a year and have been super happy with it. THanks
Describe the bug
Using the HA add on, deconz has been working great! Have one Ikea on/off switch that suddenly stopped functioning. It was ‘greyed’ out in the Phoscon UI. In the deconz application, the device was there, but had no connections to any others. I have another Ikea on/off switch which is still working.
I restarted multiple times and finally ‘deleted’ the switch to try an pair it, but now I can’t add it at all. I hit the “pair” button on the switch 4 times and the red LED blinks 4 times, but deconz fails to make a connection.
Don’t know how one could reproduce. It has been solid for about a year, then was not functional about 7 days ago and has remained that way.
Expected behavior
I expected to be able to re-pair the device after removing it.
Screenshots
Environment
- Host system: Raspberry Pi 4
- Running method: Home Assistent deCONZ Add-on
- Firmware version: 26660700
- deCONZ version: 2.12.06 / 8/19/2021
- Device: ConBee II
- Is there any other USB or serial devices connected to the host system? If so: Which? One Nortek HUSBZB-1 only using Z-wave and one samsung NVME 256GB drive (which hassos runs off of).
deCONZ Logs
The ‘copy’ button on the debug logs doesn’t seem to be working (multiple browsers on windows 10). If needed I can try to get them some other way?
Additional context
Thank you very much for any help. I have an aquara switch that has never really worked correctly, but the Ikea ones were solid. Would be great to get this working again as I plan to buy several more. Thanks again!
