I have four of these GU10 colored lights … connected to Phoscon with some problems but in the end everything is ok. The lights are however activated by a classic wall switch. I created a scene on Homekit (connected via Homebridge) where three of the four lights go out and one stays on at 30%.
The problem is that when I turn off the general wall switch light and turn it back on, all the lights go back to 100% while the light set at 30% stays at 30%.
I had Philips spotlights that every time I turned the light off and on they all returned to 100%.
There is no possibility to set the lights that can return to a preset state each time when the power is removed and reactivated?
Thank you
