I’ve loaded the the IKEA Parasoll DDF as per Github DDF for Ikea Parasoll open/close sensor by SwoopX · Pull Request #7445 · dresden-elektronik/deconz-rest-plugin · GitHub into the devices folder on my RPI, after that the IKEA sensor did show up in my Domoticz Devices list, but it does not function. When I trigger the sensor (open/close door) there’s no change in Domoticz.
- Host system: Raspberry Pi 3B
- Running method: Raspbian Bullseye - Domoticz 2024.2
- Firmware version: 26660700
- deCONZ version (not Home assistant Addon version!): (2.xx.yy)
- Device: ConBee II
- Do you use an USB extension cable: yes (in order to create some distance between Z-Wave & Conbee stick)
- Is there any other USB or serial devices connected to the host system? Yes; Z-Wave & RFXCOM
Would anyone know if I’m doing something wrong and how this can be fixed so I can use the Parasoll door sensor? Thanks in advance!
