I updated to the newest firmware of Conbee III and also updated deconz. But there are still no consumtion values available.
I found the issue IKEA INSPELNING Smart Plug with kWh meter · Issue #7948 · dresden-elektronik/deconz-rest-plugin · GitHub
But I found no solution.
Is there a solution?
Hello, the DDF is not yet merged, so you need to install it yourself for the moment.
Is it possible to get the right link?
I tried the link in the second Post
Modified bundles can be downloaded here.
But this link return 404 Page not found
I have tried it ATM, it’s working here.
Sorry!
I didn’t login to github.
Now I downloaded the Bundle. zip.
But i was not able to Imprt this file in the Phoscon App.
I get the Message Import failed.
I also tried to extract and upload each file.
But it also didn’t work.
You can’t import a zip. Needs to be .ddb
I think it should work, because in the Phoscon App the suggestet file selection ist *.ddb, *.ddf, *.zip
But I also tried to extract and upload each file.
This works most time. But on some files I get also the import failure.
After I uploaded other files I’m able to upload the file with failure also.
But this are so many files to upload.
