IKEA Inspelning missing consumption valutes
Hi
IKEA Inspelning is only displayed as a switch and no power consumption values are displayed, although this is possible with the IKEA hub itself. However, I do not want to use the IKEA hub but Conbee II. Will there be an update or have I set something up incorrectly? What could be the issue? I can only toggle the switch on and off in Home Assistant and in the Phoscon, but can’t read out any consumption values.
The device is not supported yet, which is why it’s only showing switching.
There’s a GitHub issue open afaik.
Thank you for that.
Can you provide the link to the GitHub issue?
I wasn’t able to find it.
Thanks in advance.
If you search the github issues for the device name, it shows up.
