I have a develco siren which is added to deCONZ. I would like to make it beep shortly when the alarm system is armed. Via deCONZ I’m able to use “squawk” and use a “squawk level” as the option to choose which beep I want.
The device is not in the supported list, but since I can make it do what I want via the deCONZ (VNC) GUI, I was wondering if I’m able to do it via the API?
There is some possiblities, but not sure you will found the one you need https://github.com/dresden-elektronik/deconz-rest-plugin/issues/4432#issuecomment-782841021
