after a day of maintenance on my home server which also runs deconz as a container i have massive problems with delays in my zigbee network. The Conbee II is directly connected to the host.
In the logs I see different messages which I cannot evaluate.
e.g.
11:28:17:920 read attributes of 0x3C2EF5FFFExxxxxx cluster: 0x0006: [ 11:28:17:921 0x0000 11:28:17:921 ]
11:28:17:921 add task 4494 type 19 to 0x3C2EF5FFFExxxxxx cluster 0x0006 req.id 230
11:28:17:922 Poll APS request 230 to 0x3C2EF5FFFExxxxxx cluster: 0x0006
11:28:17:943 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:003 node 0x00178801081DF717 leave wait state
11:28:18:044 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:144 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:243 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:343 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:443 delay sending request 230 dt 3 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:543 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:643 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:743 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:843 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:18:943 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:043 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:144 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:243 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:343 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:443 delay sending request 230 dt 4 ms to 0x3C2EF5FFFExxxxxx, ep: 0x01 cluster: 0x0006 onAir: 1
11:28:19:543 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
11:28:19:544 APS-DATA.request id: 230, addrmode: 0x03, addr: 0x3C2EF5FFFExxxxxx, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
11:28:19:545 asdu (length: 5): 1039000000
11:28:19:662 Poll APS confirm 230 status: 0xE1
11:28:19:663 drop item attr/modelid
11:28:19:664 drop item attr/swversion
11:28:19:665 drop item state/bri
11:28:19:665 drop item state/colormode
11:28:19:666 0x3C2EF5FFFExxxxxx error APSDE-DATA.confirm: 0xE1 on task
11:28:19:666 Erase task req-id: 230, type: 19 zcl seqno: 57 send time 0, profileId: 0x0104, clusterId: 0x0006
or
11:31:30:998 add task 5066 type 11 to 0x842E14FFFE1yyyyy cluster 0x0008 req.id 198
11:31:31:043 delay sending request 198 dt 0 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:143 delay sending request 198 dt 0 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:244 delay sending request 198 dt 0 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:343 delay sending request 198 dt 0 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:443 delay sending request 198 dt 0 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:545 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:643 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:743 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:844 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:31:943 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:043 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:143 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:243 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:343 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:443 delay sending request 198 dt 1 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:544 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:643 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:743 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:843 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:32:943 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:043 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:143 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:243 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:343 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:444 delay sending request 198 dt 2 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:543 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:644 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:743 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:843 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:33:943 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:043 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:143 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:244 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:343 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:443 delay sending request 198 dt 3 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:544 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:644 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:743 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:843 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:34:943 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:044 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:143 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:243 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:343 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:443 delay sending request 198 dt 4 ms to 0x842E14FFFE1yyyyy, ep: 0x01 cluster: 0x0008 onAir: 1
11:31:35:543 APS-DATA.request id: 198, addrmode: 0x03, addr: 0x842E14FFFE1yyyyy, profile: 0x0104, cluster: 0x0008, ep: 0x01 -> 0x01 queue: 5 len: 6 tx.options 0x04
11:31:41:208 Erase task req-id: 198, type: 11 zcl seqno: 108 send time 5, profileId: 0x0104, clusterId: 0x0008
11:31:41:208 APS-DATA.confirm id: 198, status: 0x00 SUCCESS
11:31:41:209 APS-DATA.confirm request id: 198 -> erase from queue
11:31:41:284 aps request id: 198 finished, erase from queue
11:51:18:673 APS-DATA.request id: 115, addrmode: 0x03, addr: 0x3C2EF5FFFEEFuuuu, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 2 len: 41 tx.options 0x04
11:51:18:675 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:693 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:744 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:794 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:844 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:895 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:943 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:18:993 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:044 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:095 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:144 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:193 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:244 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:293 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:345 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:393 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:443 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:493 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:546 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:595 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:644 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:693 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:744 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:745 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:793 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:845 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:895 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:944 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:19:993 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:044 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:093 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:143 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:193 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:244 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:294 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:345 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:393 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:444 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:493 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:544 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:593 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:646 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:695 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:745 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:794 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:844 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:845 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:893 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:944 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:20:993 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:044 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:093 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:144 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:193 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:243 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:293 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:344 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:393 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:444 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:493 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:544 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:553 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:21:562 asdu (length: 6): 115E006B0000
11:51:21:562 Delay APS request id: 115 to 0x967B, profile: 0x0104 cluster: 0x0300 node already has busy 2
11:51:22:687 APS-DATA.confirm id: 115, status: 0x00 SUCCESS
11:51:22:687 APS-DATA.confirm request id: 115 -> erase from queue
11:51:22:724 aps request id: 115 finished, erase from queue
11:52:59:115 APS-DATA.confirm id: 108, status: 0x00 SUCCESS
11:55:09:923 APS-DATA.request id: 115, addrmode: 0x03, addr: 0x70AC08FFFEC7xxxx, profile: 0x0000, cluster: 0x0031, ep: 0x00 -> 0x00 queue: 1 len: 2 tx.options 0x00
11:55:10:087 APS-DATA.confirm id: 115, status: 0xE1
11:55:10:088 unhandled APS-DATA.confirm id: 115 status 0xE1
In some cases the request do not have an impact on e.g. the light - it seems the request times out?
I already switched the zigbee chanal - no effect …
In general, I have not changed anything in the setup. The server was temporarily started in a different part of the house - but is now back in the same place where everything was already working fine. No new software / hardware or new devices have been added to the network.
Does anyone have any ideas for me where I can look further or what I can do to fix the problem?
