I connected a hue lamp today and it flashing every x minutes when switched on.
16:57:04:262 0x90FD9FFFFE8320E8 error APSDE-DATA.confirm: 0xE9 on task
16:57:11:944 0x90FD9FFFFE8320E8 error APSDE-DATA.confirm: 0xE1 on task
Can you share a full log?
Either way, the 0xE1 isn’t promising:
17:05:47:510 Websocket disconnected 127.0.0.1:57706, state: 0, close-code: 1000, reason:
17:05:49:435 0x00178801036B9095 error APSDE-DATA.confirm: 0xD0 on task
17:05:50:077 0x90FD9FFFFEFADCF1 error APSDE-DATA.confirm: 0xE9 on task
17:05:53:165 0xD0CF5EFFFE003421 error APSDE-DATA.confirm: 0xE9 on task
17:05:59:521 binding for cluster 0x0000 of 0x90FD9FFFFE8320E8 exists (verified by reporting)
17:05:59:521 binding for cluster 0x0006 of 0x90FD9FFFFE8320E8 exists (verified by reporting)
17:05:59:524 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x90FD9FFFFE8320E8 (seems to be active)
17:05:59:524 binding for cluster 0x0300 of 0x90FD9FFFFE8320E8 exists (verified by reporting)
17:05:59:524 skip configure report for cluster: 0x0300 attr: 0x0007 of node 0x90FD9FFFFE8320E8 (wait reading or unsupported)
17:05:59:524 skip configure report for cluster: 0x0300 attr: 0x0003 of node 0x90FD9FFFFE8320E8 (seems to be active)
17:05:59:525 skip configure report for cluster: 0x0300 attr: 0x0004 of node 0x90FD9FFFFE8320E8 (seems to be active)
17:05:59:525 skip configure report for cluster: 0x0300 attr: 0x0008 of node 0x90FD9FFFFE8320E8 (seems to be active)
17:05:59:648 0x90fd9ffffe8320e8 found group 0x3E1B
17:05:59:649 0x90fd9ffffe8320e8 found group 0xFFF0
17:05:59:649 0x90fd9ffffe8320e8 found group 0x0004
17:06:00:608 Bind response success for 0x90fd9ffffe8320e8 ep: 0x01 cluster: 0x0008
17:06:00:611 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x90FD9FFFFE8320E8 (seems to be active)
17:06:01:521 binding for cluster 0x0000 of 0x000B57FFFEB9E3F0 exists (verified by reporting)
17:06:01:522 binding for cluster 0x0006 of 0x000B57FFFEB9E3F0 exists (verified by reporting)
17:06:01:522 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x000B57FFFEB9E3F0 (seems to be active)
17:06:01:605 Bind response success for 0x000b57fffeb9e3f0 ep: 0x01 cluster: 0x0008
17:06:01:606 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x000B57FFFEB9E3F0 (seems to be active)
17:06:01:847 0x000b57fffeb9e3f0 found group 0xFFF0
17:06:01:848 0x000b57fffeb9e3f0 found group 0x0003
17:06:24:556 Device TTL 809 s flags: 0x7
17:06:33:520 binding for cluster 0x0000 of 0x000B57FFFE8FD7FA exists (verified by reporting)
17:06:33:521 binding for cluster 0x0006 of 0x000B57FFFE8FD7FA exists (verified by reporting)
17:06:33:521 skip configure report for cluster: 0x0006 attr: 0x0000 of node 0x000B57FFFE8FD7FA (seems to be active)
17:06:33:754 Bind response success for 0x000b57fffe8fd7fa ep: 0x01 cluster: 0x0008
17:06:33:755 skip configure report for cluster: 0x0008 attr: 0x0000 of node 0x000B57FFFE8FD7FA (seems to be active)
17:06:34:060 0x000b57fffe8fd7fa found group 0x8F51
17:06:34:060 0x000b57fffe8fd7fa found group 0xFFF0
17:06:34:061 0x000b57fffe8fd7fa found group 0x0003
17:06:35:875 0x90FD9FFFFEFADCF1 error APSDE-DATA.confirm: 0xE9 on task
17:06:42:112 DeviceAnnce of LightNode: 0x00178801036b9095 Permit Join: 0
17:06:43:009 0x00178801036b9095 found group 0xFFF0
17:06:46:519 Skip idle timer callback, too early: elapsed 491 msec
17:06:51:520 GW firmware version is up to date: 0x26720700
17:07:24:560 Device TTL 749 s flags: 0x7
17:07:34:338 reuse dead link (dead link container size now 3)
17:07:37:221 reuse dead link (dead link container size now 2)
17:07:37:222 reuse dead link (dead link container size now 1)
17:07:44:308 DeviceAnnce of LightNode: 0x00178801036b9095 Permit Join: 0
17:07:44:563 0x00178801036b9095 found group 0xFFF0
17:07:46:191 0xD0CF5EFFFE003421 error APSDE-DATA.confirm: 0xE9 on task
17:07:53:520 Skip idle timer callback, too early: elapsed 244 msec
17:08:08:271 0xD0CF5EFFFE003421 error APSDE-DATA.confirm: 0xE9 on task
17:08:16:061 0xD0CF5EFFFE003421 error APSDE-DATA.confirm: 0xE9 on task
17:08:24:563 Device TTL 689 s flags: 0x7
17:08:58:520 Skip idle timer callback, too early: elapsed 149 msec
17:08:59:670 0x90FD9FFFFEFADCF1 error APSDE-DATA.confirm: 0xE9 on task
17:09:24:560 Device TTL 629 s flags: 0x7
17:09:34:664 0xD0CF5EFFFE004B3B error APSDE-DATA.confirm: 0xE9 on task
The device announce indicates that the devices firmware is rebooting. Meaning they reboot everytime. Are they new? Is this only one light doing this?
I think it is a faulty light, it was also a lot offline on the hue hub.
I replaced it with another one (exactly the same) and now it is fine
