Need help with two hue buttons as light switch.
So I’ve added to hue buttons for the sleeping room to control two lights.
I’ve added them in the switch editor. Now the use case is: enter sleeping room activate the lights via dimmer at the door and turn off the light with the dimmer at the bed.
But this is not working. Only the last dimmer I’ve added to the scenario is functional working.
Both dimmers are configured identically.
If I use the IKEA dimmers that use case is possible.
Any ideas?
Thanks!
@de_employees can you check?
hey,
@Mimiix I’ve removed everything and re-added all switches…
Suddenly it’s working!
thanks and cheers
