I really am not sure what’s going on.
Does deconz still run?
I just noticed this myself. It seems that since 2.14 (on windows) the webapp files are no longer installed. 2.13 does, but nothing since.
Was there a reason webapp was taken out? If so, will the docs be updated to reflect this?
Oh this is interesting.
Let me check with Manup
And by curiosity what is the result of
http://Deconz_Local_ip/api/config
You need to have a json
And you can’t try with the lcal host ip 127.0.0.1 on the same machine than deconz is running ?
That is the result:
The file /api/config couldn’t be found.
And
curl http://127.0.0.1:81/api/config
The file /api/config couldn't be found.
Ok …
It’s like the webserver is running, but without contain …
And if you make just http://Deconz_Local_ip ? on my side I have the old web app.
You have updated something ?
At http://xx.yy.zz.30:81? there is only the standard screen:
“Please wait while searching for gateways.”
Have you updated anything?
No, only the PlugIns in HomeBridge.
But I have a feeling that the problems started on Sunday, 10/30/2022. That was on the day of the time change.
And you have an headless setup ?
Yes. I have.
Can you please share to which location deCONZ is installed and your Windows version, in my setup on Win7 I don’t see this issue but like to test with similar setup.
Sorry. I am on ubuntu. Headless.
It was deleted by accident (only the old webapp from 2016). But should be available again in the current deconz version I think?
