whoami
August 12, 2022, 5:18pm
1
Hi, I‘m wondering if the IKEA Tradfri Control Outlet E1703 can be integrated, while the E1603 version is already officially supported (link ).
As its not officially supported is there a way, how to integrate it?
Sorry for the noob question, I‘m actually one
Mimiix
August 12, 2022, 6:09pm
2
It should work, even if it’s not on the list. Did you check the github list?
Nevertheless, there should be a little pin hole on it.
whoami
August 12, 2022, 6:44pm
3
Well I tried it but even using the small button with a needle it was not found.
So what I did:
Using Phoscon App, Add new Device
Inclusion mode started
Putting Tradfri into socket
Clicking on this button with a needle
Shall I do any step different/re-order?
Mimiix
August 12, 2022, 6:46pm
4
Can you share logs while pairing? See #deconz on how to do so.
Smanar
August 12, 2022, 7:45pm
5
To factory reset the TRADFRI control outlet, press and hold the reset button (pinhole underneath the light, located at the top (bottom if UK) of the outlet) with a paperclip until the white light starts fading. Hold onto the button for a few more seconds, then release. After this, the outlet will automatically connect.
Perhaps similar issue Ikea E1703 smart plugs keep disappearing and can't be re-paired reliably · Issue #6262 · dresden-elektronik/deconz-rest-plugin · GitHub
whoami
August 13, 2022, 10:24am
6
Thank you @Smanar , this was actually the solution how it was able to integrate.
Also thank you @Mimiix for your support
