Background: From a few weeks ago, I suddenly can not control my smart switches with RaspberryPi 4 + Homebridge + Hue plugin + deCONZ, which has been working fine for over a year. I thought my RaspBee is broken as it happened once before, so bought a new RaspBee2 from Amazon and replaced the old one. Then I can set up the network via Phoscon again (first one in the screenshot above) and can successfully control lights via Phoscon, but I still couldn’t control switches via Homebridge & Hue plugin & deCONZ (Homebridge can connect to Phoscon via websocket but not recognise accessories).
I don’t think so. I can login to the 1st one and enable authentication so Homebridge plugin can find it. However, I couldn’t find any other way to validate all these before trying to remove the 2nd one completely. Eliminating possibilities one by one. I don’t want to format the whole RaspberryPi because deCONZ or Phoscon is not working.
You have 2 gateway displayed ? even using the phoscon public adress ?
And on the discovery you have only one, the one called "“Phoscon”. So Third app will use this ip on port 80.
You have tried with another browser ? from your smartphone for exemple ?
And if you close your deconz session ? both gateway disapear ?
