How to check that ConBee II is correct working
I wanted to reactivate my ConBee II stick after one or two years but I can’t get my innr plug being connected. The plug is working well with a philips hue bridge. When I bought the stick and tested it with that plug I got a connection.
I have flashed latest firmware and I’m using the latest phoscon/deconz software (on windows).
It seems that the radio on the stick doesn’t work.
How can I check that?
In the meanwhile I have activated debugging and retried to connect the plug.
Maybe there is some activity from the radio?
12:07:04:596 APS-DATA.request id: 216, addrmode: 0x02, addr: 0xFFFC, profile: 0x0000, cluster: 0x0036, ep: 0x00 → 0x00 queue: 0 len: 3 tx.options 0x00
12:07:04:597 asdu (length: 3): 080001
12:07:04:719 aps request id: 216 prf: 0x0000 cl: 0x0036 timeout (confirmed: 0) to 0x0000000000000000 (0xFFFC)
12:07:04:720 aps request id: 216 prf: 0x0000 cl: 0x0036 timeout NOT confirmed to 0x0000000000000000 (0xFFFC)
12:07:04:819 aps request id: 216 failed, erase from queue
12:07:04:820 emit artificial APSDE-DATA.confirm id: 216 0xA7
12:07:04:908 aps request id: 216 failed, erase from queue
12:07:05:259 APS-DATA.confirm id: 216, status: 0x00 SUCCESS
12:07:05:260 APS-DATA.confirm id: 216, status: 0x00, match: 0
12:07:07:606 APS-DATA.request id: 217, addrmode: 0x02, addr: 0xFFFC, profile: 0x0000, cluster: 0x0036, ep: 0x00 → 0x00 queue: 0 len: 3 tx.options 0x00
12:07:07:607 asdu (length: 3): 094101
12:07:07:607 APS-DATA.request id: 218, addrmode: 0x02, addr: 0xFFFC, profile: 0xA1E0, cluster: 0x0021, ep: 0xF2 → 0xF2 queue: 1 len: 6 tx.options 0x00
12:07:07:607 asdu (length: 6): 1902020B2800
12:07:07:608 [ZGP] send GP proxy commissioning mode
12:07:07:728 aps request id: 217 prf: 0x0000 cl: 0x0036 timeout (confirmed: 0) to 0x0000000000000000 (0xFFFC)
12:07:07:729 aps request id: 217 prf: 0x0000 cl: 0x0036 timeout NOT confirmed to 0x0000000000000000 (0xFFFC)
12:07:07:820 aps request id: 217 failed, erase from queue
12:07:07:821 emit artificial APSDE-DATA.confirm id: 217 0xA7
12:07:07:912 aps request id: 217 failed, erase from queue
12:07:08:006 aps request id: 218 prf: 0xA1E0 cl: 0x0021 timeout (confirmed: 0) to 0x0000000000000000 (0xFFFC)
12:07:08:007 aps request id: 218 prf: 0xA1E0 cl: 0x0021 timeout NOT confirmed to 0x0000000000000000 (0xFFFC)
12:07:08:099 aps request id: 218 failed, erase from queue
12:07:08:100 emit artificial APSDE-DATA.confirm id: 218 0xA7
12:07:08:192 aps request id: 218 failed, erase from queue
12:07:08:268 APS-DATA.confirm id: 217, status: 0x00 SUCCESS
12:07:08:269 APS-DATA.confirm id: 217, status: 0x00, match: 0
12:07:08:307 APS-DATA.confirm id: 218, status: 0x00 SUCCESS
12:07:08:308 APS-DATA.confirm id: 218, status: 0x00, match: 0
Has someone an idea about these messages?
Thanks,
Martin
Hello again,
solved by myself :slight_smile:
I changed channel from 20 to 15 and now I could connect the plug and switch it on and off.
So the radio of my stick seems to work.
