@WizBangCrash did you do anything else to trigger the devices to actually change to the new channel? I’m also having the same problems with occasionally devices disconnecting/not responding. I’m also using ZHA. In the configuration.yaml I have the channel set to 25 but looking in the logs it used 11. so then I cam across this post and now I actually see it in the logs as channel 25! However, I’ve waited for 20 minutes now but still no devices are online.
@ChrisHae do you have any tips?
The log is available here; https://file.io/YtUfbXMgZaMb
They are basically filled with entries like below. But the strange thing is if you look in the logs you see at a certain point a lot of channel configuration entries and confirmations that the devices are online again.
2021-09-08 10:12:05 DEBUG (MainThread) [homeassistant.components.zha.entity] light.werkkamer_spot_2: polling current state
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 187 under 188 request id, data: b'00bb000000'
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (20, 188, 0, <DeconzAddressEndpoint address_mode=2 address=0x0B52 endpoint=11>, 260, 6, 1, b'\x00\xbb\x00\x00\x00', 2, 0)
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 188]
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 188: d0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0xbc 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x0b52 endpoint=11>, status: 0xd0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 188 req id frame: TXStatus.NWK_ROUTE_DISCOVERY_FAILED
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy.device] [0x0b52] Delivery error for seq # 0xbb, on endpoint id 11 cluster 0x0006: message send failure
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 189 under 190 request id, data: b'00bd000000'
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (20, 190, 0, <DeconzAddressEndpoint address_mode=2 address=0x0B52 endpoint=11>, 260, 8, 1, b'\x00\xbd\x00\x00\x00', 2, 0)
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 190]
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 190: d0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0xbe 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x0b52 endpoint=11>, status: 0xd0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 190 req id frame: TXStatus.NWK_ROUTE_DISCOVERY_FAILED
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy.device] [0x0b52] Delivery error for seq # 0xbd, on endpoint id 11 cluster 0x0008: message send failure
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 191 under 192 request id, data: b'00bf0008000700030004000240'
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (28, 192, 0, <DeconzAddressEndpoint address_mode=2 address=0x0B52 endpoint=11>, 260, 768, 1, b'\x00\xbf\x00\x08\x00\x07\x00\x03\x00\x04\x00\x02@', 2, 0)
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 192]
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 192: d0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0xc0 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x0b52 endpoint=11>, status: 0xd0
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 192 req id frame: TXStatus.NWK_ROUTE_DISCOVERY_FAILED
2021-09-08 10:12:05 DEBUG (MainThread) [zigpy.device] [0x0b52] Delivery error for seq # 0xbf, on endpoint id 11 cluster 0x0300: message send failure
2021-09-08 10:12:05 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0B52:11:0x0300]: failed to get attributes '['color_mode', 'color_temperature', 'current_x', 'current_y', 'color_loop_active']' on 'light_color' cluster: [0x0b52:11:0x0300]: Message send failure
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 166>, 0]
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 184: d0
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0xb8 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0xf8f7 endpoint=11>, status: 0xd0
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Error while sending 184 req id frame: TXStatus.NWK_ROUTE_DISCOVERY_FAILED
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy.device] [0xf8f7] Delivery error for seq # 0xb7, on endpoint id 11 cluster 0x0008: message send failure
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 193 under 194 request id, data: b'00c10008000700030004000240'
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (28, 194, 0, <DeconzAddressEndpoint address_mode=2 address=0xF8F7 endpoint=11>, 260, 768, 1, b'\x00\xc1\x00\x08\x00\x07\x00\x03\x00\x04\x00\x02@', 2, 0)
2021-09-08 10:12:08 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 194]
