HomeAssitant Rasp Pi4 - deCONZ don’t start anymore
In the HomeAsssistant, the deCONZ no longer starts.
I uninstalled it - restart - reinstalled - restart and much more. no chance.
Via ssh of course no more access. Only via the HomeAssistant and the “Terminal & SSH” plugin, which no longer allows access from a client and is only very limited by the commands in the WEB interface. Via SAMBA Plugin Access.
But I’m not a specialist in Linux.
Konfiguration: Raspberry Pi 4 (32-bit)
Home Assistant:
  • Core2024.10.4
  • Supervisor2024.10.3
  • Operating System13.0
  • Frontend20241002.4
    deCONZ:
    Current version: 7.0.0
    Phoscon-GW:
    deCONZ
    von Dresden Elektronik Version: 2.28.1
Protokoll deCONZ Plugin:
cont-init: warning: some scripts exited nonzero
s6-rc: warning: unable to start service legacy-cont-init: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/firmware.sh
[12:21:18] INFO: Path | Serial | Type
/dev/ttyACM0 | DE2426487 | ConBee_II
cont-init: info: /etc/cont-init.d/firmware.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/novnc.sh
sed: can’t read /usr/share/novnc/vnc_lite.html: No such file or directory
cont-init: info: /etc/cont-init.d/novnc.sh exited 2
[12:21:25] INFO: Path | Serial | Type
Hi
As we are an English community, please edit your post to English.
I could solve the problem !!
1.) deinstall complete the deCONZ plugin include all data
2.) deinstall in the services the phoscon
3.) shut down the rasp
4.) check if the ConBee is on the 1,5 meter USB cable and far from the rasp
5.) Start the rasp and wait till he find a new Device “Zigbee Home Automation”
6.) do the configuration as the assistant start
7.) he will find all devices exclude the thermo sensor. this you will reconnect to the Zigbee.
see the screenshots :smile:
