SOLVED - hardware issue - no Support needed
Dear community,
As I might not be the only one with the issue, does somebody has a tutorial how to setup ConBee 2 in combination with Duck DNS in home assistant?
Details - but not needed in case tutorial is available
Installation was running so far very good on my Raspberry PI 4
- ConBee 2 USB stick has been recognized
- deCONZ is running version 6.12.0 installed via Add-ons
- Duck DNS running well version 1.14.0
- Phoscon Web App is running version 2.14.1 / 6.2.2022
Now my issue:
When I want ot integrate deCONZ entity in home assistant I have start app-connect in Phoscon. To connect deCONZ I need to proved HOST to create API-Key which is not working. Port-Forwarding has been made accordingly.
Host I provided: https://myadress.duckdns.org
Thank you for your support
