Hi all,
I have an aqara temperature sensor im my balcony for measuring the outdoor temp. and humidity. It was working fine but in low external temperatures was not so accurate. So I tried to calibrate it using the below method (through home assistant)
Calibrating temperature sensors using the deCONZ service (bogdanbujdea.dev)
Although this method fixed the problem, the sensor started to drain the battery. In a few hours the battery drained from 80% to 0%. I tried a new battery and in half an hour was at 30%!
I tried to reset it, and though dencoz app
and by holding the button for 5 sec, but the problem remains. I lost 3 batteries until now.
Is there a way to fix it or should I just sent it to garbage?
