Heiman Smoke Sensor - no state updates - after upgrade from stable deconz 2.12 --> 2.21.2
I upgraded my deCONZ version from deCONZ stable 2.12 to stable 2.21.2.
Firmware of ConBeeII was upgraded to version 26780700.
My zigbee network has about 63 nodes with nodes/plugs from Ledvance/Osram, Innr, Nous, Ikea, Heiman
and with several endpoints: Aqara sensors, Eurotronic ZigBee Spirit, Tradfri Motion sensors - all working excellent with the new versions!!!
Describe the bug
I start deCONZ gui-mode and can see deconz establishing drawn connections to all of my devices at startup - even to all of my smoke sensors with all states (battery,state,reachable,..) are getting updated once.
I have got a total of 15 Heiman smoke sensors in 3 groups of clones with different Problems:
7 Schwaiger ZHS20 (Heiman HS1SA-M - Model Identifier: SMOK_YDLV10 DateCode: 20150330)
==> Are all getting state updates in between 3-10 hours! BUT: Phoscon shows a few of them as "not reachable" although they were updated successfully before.
3 Orvibio SF21 smoke sensor swversion 1.1.1
==> Are reachable on deconz startup with all states getting updated, but after that, they never get updated again.
I can see the sensors talking to deconz from time to time - blue dot blinking. But no refreshing of the states.
5 Heiman SmokeSensor-EF-3.0 DateCode: 2020.7.10
==> Are reachable on deconz startup with all states getting updated, but after that they never get updated again.
The same here - blue dot blinking. But no refreshing of the states.
Of course I tested to reset and re-pair them - but with the same effect! They can be included to the network by Phoscon correctly, are getting one update and then stop working
Steps to reproduce:
Start deconz gui mode - every node and sensor found!
Only effected Heimans get no status update at all, but are talking to the mesh from time to time. But (perhaps) nobody listens to them …
Tested over 35 hours!!! No updates!
Expected behavior
Like in deconz Version 2.12 before - every smoke sensor sends state updates (batteryPercent,batteryState,reachable,state,fire) within max 10 hours to deconz/phoscon. All kinds of Heiman clones did this before.
Status update in between 3-10 hours - battery, reachable,
Environment
Host system: Raspberry Pi 4
Running method: Raspbian Buster
Firmware version: 26780700
deCONZ version: (2.21.02)
Device: ConBee II
Do you use an USB extension cable: yes
deCONZ Logs
Tell me whats needed - I will post them. Which debug levels are important???
Please share some logs. In #deconz you can find out what levels :slight_smile:
I logged deCONZ from 8:15 - 10:52 but the log is way to big for pastebin 10MB. So I deleted many things… and it is still to big with the log setting:
/usr/bin/deCONZ -platform minimal --dbg-aps=2 --dbg-info=2 --dbg-error=2 | tee debug.txt
Is there an easy way to filter the log for you? Our how I can send you the whole log?
So I started with deconz startup:
Startup Startup DB
After no refreshing in Phoscon I triggered OG.Ar.Rauchmelder (SmokeSensor-EF-3.0) with the Test-Button. After that its getting refreshed… but like I said - then it stops getting updates - tested for 35 hours before. I searched for device mac and copied around…
OG.Ar.Rauchmelder - no updates
OG.Ar.Rauchmelder - triggered
I found a part where OG.Ar.Rauchmelder (12:18:06) talks…
OG.Ar.Rauchmelder - hours after triggering
but phoscon is still believing the last message came 10:44:04 - which was my test-button trigger.
Thanks
I check Monday when I’m at PC again.
Ok, feel free to ask for more specific log data on monday - I am at the PC, too.
Still logging since 8:15 today…
In my first Log I found wrong DB entries. DB thinks I am still using 2.12.06 and the wrong Firmware 0x26660700.
Phoscon knows better:
  • Version 2.21.02 / 19.9.2022
  • 26780700
Phoscon
Beam
Logs doesn’t show anything worrying.
Can you provide me some longer logs (several minutes), to see whats going on in the network?
Additionally, can you provide a screenshot of your deCONZ gui (map with all the nodes)
Also: Can you provide a screenshot of the basic cluster of one of the sensors?
Kind regards,
Thats what I looks like in fhem (phoscon the most sensors are greyed out and not reachabel) after 3 days.
In 2.12 the biggest value was “for 3-6 hours not seen.”
My network looks like this:
15 smoke sensors: (these are the 3 types I have for example)
A few of the SMOK_YDLV10 are still refreshing, but EF-3.0 and SF21 are dead/not reachable for phoscon at all!
Ke.Hz.Rauchmelder
00:50:43:c9:03:24:3a:3f
005043c903243a3f
manufacturername: Heiman
modelid: SMOK_YDLV10
OG.Ar.Rauchmelder
80:4b:50:ff:fe:ff:e8:06
804b50fffeffe806
manufacturername: HEIMAN
modelid: SmokeSensor-EF-3.0
OG.FL.Rauchmelder
00:0d:6f:00:10:dd:0c:6c
000d6f0010dd0c6c
modelid: SF21 smoke sensor
Before killing the 3 days log and restart deCONZ-GUI for you ;), I pressed the test button for all the three sensors above and every sensor showed up in phoscon again - surprise!!!
When I looked at the log
Triggerd 3 sensors - after 99 hours not refreshing!,
the three showed up in phoscon again!
Longer Startup-Log
Basic Cluster Heiman EF-3:
Basic Cluster Schwaiger ZHS20:
Basic Cluster Orvibio SF21:
Can you please provide a screenshot of the basic cluster?
Forgotten - I edited it above!
I have no clue whats happening with the second one.
@manup / @Smanar can you check the Orivbio screen (basic cluster). Has an odd Model identifier.
However, There has been 0 changes to the devices mentioned between those versions.
What i do notice, is that your network contains quiet a few bad connections. Is there a way for you to improve those?
Network had no problem over years … Yes, from time to time one or two smoke sensors got lost, but reset and re-pair an everything was good again for month.
House with 3 Floors and reinforced concrete ceilings.
But:
The three test-sensors are now 1m away from the Conbee II for testing. And like I said before, every sensor updates the phoscon sensor status immediately, if I press the test button - doesn’t matter if in cellar or elsewhere in the house.
Other example:
OG.K.FL.Rauchmelder
00:50:43:c9:03:24:42:8e
005043c90324428e
Was not moved neither far away from ConbeeII:
Status never got refreshed even after restart today, but in the log last night 4:42 and every 2h before - there are this entries - so why phoson does not notice, although it’s already logged by deconz with the right timestamps?
For me that’s not a weak connection problem.
Phoscon only says:
OG.K.FL.Rauchmelder
So, after comparing messages, which are send after hitting the test button and which are recognized by phoscon AND fhem correctly and the ignored 2-6hourly status updates by the sensors, which are never reaching phoscon or fhem…
phoscon/fhem don’t get informed about 2-6hourly sensor update messages looking like this:
22:23:03:325 Websocket 192.168.1.120:33684 send message: {“attr”:{“id”:“125”,“lastannounced”:null,“lastseen”:“2023-05-07T20:23Z”,“manufacturername”:“HEIMAN”,“modelid”:“SmokeSensor-EF-3.0”,“name”:“OG.Ar.Rauchmelder”,“swversion”:“2020.7.10”,“type”:“ZHAFire”,“uniqueid”:“80:4b:50:ff:fe:ff:e8:06-01-0500”},“e”:“changed”,“id”:“125”,“r”:“sensors”,“t”:“event”,“uniqueid”:“80:4b:50:ff:fe:ff:e8:06-01-0500”} (ret = -1092814640)
But by hitting the test-button: phoscon/fhem are succesfully updated with this message:
10:53:13:737 Websocket 192.168.1.120:33684 send message: {“e”:“changed”,“id”:“125”,“r”:“sensors”,“state”:{“fire”:true,“lastupdated”:“2023-05-08T08:53:13.736”,“lowbattery”:false,“tampered”:false},“t”:“event”,“uniqueid”:“80:4b:50:ff:fe:ff:e8:06-01-0500”} (ret = -1092815784)
So, why the messages look so different? Is it possible that this is the reason - can I test it by myself in any way?
Not sure why that happens. @de_employees perhaps you can help?
Nope it’s normal for orvibo, there is for exemple in code
        // replace ORVIBO model IDs
        if (lightNode.modelId() == QLatin1String("abb71ca5fe1846f185cfbda554046cce"))
            lightNode.setModelId(QLatin1String("T10D1ZW dimmer"));
            lightNode.setNeedSaveDatabase(true);
        else if (lightNode.modelId() == QLatin1String("545df2981b704114945f6df1c780515a"))
            lightNode.setModelId(QLatin1String("T10W1ZW switch"));
Today I restarted everything, again. Plugged off ConbeeII for at least 20min.
Rebooted RPI4.
Resetted and re-paired nearby OG.Ar.Rauchmelder (Smoke Sensor EF-3.0).
Still the same.
It and most of the other smoke sensors refreshed one time - and no other smoke-sensor status update packet received by deconz (and there are lot of) are getting through to phoscon or fhem like I explained before.
Log is full with status updates from all smoke sensors, but no state gets refreshed (except a bunch of Schwaiger ZHS20 - SMOK_YDLV10 are still updating - but no EF-3.0 or SF21)!
Phoscon even sees less information (unreachable - no battery values - never seen), as if I start rest-api and request the sensor id for a specific sensor or ask fhem through rest-api I can even see more information.
Still only pushing test-button, updates every sensor immediately
So, really clueless…
Let’s see if / when Dresden elektronik people reply with a solution.
In the meanwhile, i recommend getting more routers as you might get some more to optimize things.
Offtopic:
"Optimizing is quite complicated.
The best ceiling-floor-hop experience I have with Conbee II, Heiman Siren and Heiman Gassensor… they are the backbone of the hole mesh over all floors.
In every floor there are several Ikea Tradfri Trafo, Ledvance/Osram Plugs, Innr Plugs, Nous Plugs, but they have all not the same signal strength through ceilings.
So what are your signal-strength favorites? - A second siren or gassensor are useless to me!"
You need routers. Mains powered devices.
Heiman Siren and Heiman Gassensor are mains powered devices! :wink:
And Osram, Innr, Nous are to weak for the ceiling hop - the mesh likes the route Conbee II, Heiman Siren, Heiman Gassensor.
