GU10 spot blue at power on
I have 2 Hue White and Color Ambiance Spot GU10
Since a few weeks they have weird behaviour. At power on (electricity) they give blue light in stead off white light.
I tried several things to solve the problem:
  • remove/add to Deconz
  • add to Hue Bridge to update the firmware
  • check the settings in Deconz VNC
  • install older version of Deconz
When I remove the spots from Deconz, they are working fine, meaning giving white light at power on
But when I add them to Deconz again, at power on I see a short delay before light is on and the light is… blue.
Is there a setting somewhere for power on behaviour?
Spot: Model LCT003
Firmware: 67.101.2
Deconz: 2.22.00 / 19-9-2022
Firmware Raspbee II: 26720700
I think I have the same problem with my LCT015 version 1.101.2. When I add it to the deCONZ via Conbee II, it randomly turns blue when I turn on the bulb from the power switch. Have you managed to find any solution?
I can record video if more description is needed.
Hy guys,
I´ve tested the LCT003 (we don´t have the LCT015 here) with the Firmware 5.11.0.10732
No strange behavior, the bulb is safing the stats after you take it from the power. So, no problem here.
But I will test it with your firmware as well guys. You will here from us in the next days.
I have recorded video of the behavior: 20230612 164047 - Sendvid
I am using the power switch on the wall.
So it´s ok on the first click but blue on the second? Really weird.
Yeah :smiley: As soon as I disconnect it from my Home Assistant deCONZ addon, it starts working normally.
We cannot reproduce the issue with a LCT003 spot, the newest firmware 11.0.10732 of it and inside of Home Assistant. Do you switch of the light via power off or via a zigbee command (via app or zigbee switch)?
I have the same issue:
I’ve got a Pi4 with a ConBee II:
  • version: 2.22.02 / 19/09/2022
  • firmware: 26780700
Multiple LCT012 with firmware: 1.101.2.
They all show they same behavior as described earlier.
Is there any way I can help to debug this?
Thanks a lot!
I forgot, similar to the thread author - I use a real switch to power off/on the lights.
Can you update the firmware of the light with a Hue bridge?
@ich Thanks for your reply.
Probably I can do that.
Interestingly, this has been working correctly before and was only an issue with the last or second to last update of deconz - docker-based container.
Any ideas what could have caused this?
Can I downgrade to an older version of deconz to crosscheck?
I had to replace one bulb.
Before adding it to deconz, the new bulb didn’t show the blue/white behaviour.
After adding it to deconz, it shows the blue/white behaviour.
Removing it from deconz, it doesn’t.
Any suggestions how to debug this?
@de_employees
I have the same issue. Yesterday I switched with two LTC007 from a HUE bridge setup to deconz. I bought both bulbs in one package (years ago), one is perfectly starting with the pre-power-off state, the second starts either with the described blue or with some white (but not the pre-power-off state). Are there any news regarding this behavior?
I also have this issue. After physical power up my lamps are blue. If I switch them off an on again, it’s normal light again.
Modell LCT003
Firmware 67.88.1
GW: Conbee II
Version 2.28.1
Firmware: 26780700
Dockerinstallation
Any solution here???
@de_employees
Just saw @ebaauw answering this on github:
This is not a bug in deCONZ; the power-on colour is a persisted setting in the light’s firmware. This setting can be accessed through the deCONZ GUI (Hue Startup Current X and Hue Startup Current Y in the Color Control cluster), and through the API (/lights/.../config/color/xy/startup). It’s probably set to [0, 0], causing the blue-ish colour. Personally I like set this to "previous", (or [65535, 65535] in the GUI) so the light powers up to its previous colour.
