I just bought a LED dimmer and there are issues with getting them working with deconz. Pairing seems to work. I see the device in deconz and also control it (Cluster 0008 Level Control).
However, it is not created in the REST API. I followed the advice from @ebaauw in Gledopto GL-C-009 not pairing · Issue #4085 · dresden-elektronik/deconz-rest-plugin · GitHub and tried reading the descriptors while searching for lights, but that does not help. It is interesting that all fields on the BASIC cluster remain empty:
Resetting and re-pairing does not change anything (except the name of the device changes. I have made a log while reading the basic cluster:
19:11:33:268 APS-DATA.request id: 10, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 0 len: 11 tx.options 0x04
19:11:33:269 asdu (length: 11): 1031000000010002000300
19:11:33:405 APS-DATA.request id: 11, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x04
19:11:33:406 asdu (length: 5): 1032000400
19:11:33:407 APS-DATA.confirm id: 10, status: 0x00 SUCCESS
19:11:33:408 APS-DATA.confirm request id: 10 -> erase from queue
19:11:33:459 aps request id: 10 finished, erase from queue
19:11:33:535 APS-DATA.request id: 12, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x04
19:11:33:536 asdu (length: 5): 1033000500
19:11:33:537 APS-DATA.confirm id: 11, status: 0x00 SUCCESS
19:11:33:538 APS-DATA.confirm request id: 11 -> erase from queue
19:11:33:565 aps request id: 11 finished, erase from queue
19:11:33:655 APS-DATA.request id: 14, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x04
19:11:33:656 asdu (length: 5): 1034000600
19:11:33:657 APS-DATA.confirm id: 12, status: 0x00 SUCCESS
19:11:33:658 APS-DATA.confirm request id: 12 -> erase from queue
19:11:33:700 aps request id: 12 finished, erase from queue
19:11:33:805 APS-DATA.request id: 15, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 11 tx.options 0x04
19:11:33:806 asdu (length: 11): 1035000700080009000A00
19:11:33:807 APS-DATA.confirm id: 14, status: 0x00 SUCCESS
19:11:33:808 APS-DATA.confirm request id: 14 -> erase from queue
19:11:33:860 aps request id: 14 finished, erase from queue
19:11:33:945 APS-DATA.request id: 17, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x04
19:11:33:946 asdu (length: 5): 1036000B00
19:11:33:947 APS-DATA.confirm id: 15, status: 0x00 SUCCESS
19:11:33:948 APS-DATA.confirm request id: 15 -> erase from queue
19:11:34:019 aps request id: 15 finished, erase from queue
19:11:34:031 poll node 84:2e:14:ff:fe:15:ac:4f-01
19:11:34:034 Poll light node LED Strip 1
19:11:34:058 APS-DATA.request id: 18, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 5 tx.options 0x04
19:11:34:062 asdu (length: 5): 1037000C00
19:11:34:064 APS-DATA.confirm id: 17, status: 0x00 SUCCESS
19:11:34:066 APS-DATA.confirm request id: 17 -> erase from queue
19:11:34:096 Poll APS request to 0x842E14FFFE15AC4F cluster: 0x0006 dropped, values are fresh enough
19:11:34:120 aps request id: 17 finished, erase from queue
19:11:34:121 APS-DATA.request id: 20, addrmode: 0x03, addr: 0x086BD7FFFE2545ED, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
19:11:34:122 asdu (length: 5): 1048000700
19:11:34:255 APS-DATA.request id: 21, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 2 len: 5 tx.options 0x04
19:11:34:256 asdu (length: 5): 1038000D00
19:11:34:257 APS-DATA.confirm id: 18, status: 0x00 SUCCESS
19:11:34:258 APS-DATA.confirm request id: 18 -> erase from queue
19:11:34:259 aps request id: 18 finished, erase from queue
19:11:34:325 APS-DATA.confirm id: 20, status: 0x00 SUCCESS
19:11:34:326 APS-DATA.confirm request id: 20 -> erase from queue
19:11:34:355 aps request id: 20 finished, erase from queue
19:11:34:358 APS-DATA.indication srcAddr: 0x182E, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 191, rssi: -67
19:11:34:361 asdu: 18480107000021c601
19:11:34:364 APS-DATA.request id: 24, addrmode: 0x03, addr: 0x086BD7FFFE2545ED, profile: 0x0104, cluster: 0x0008, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
19:11:34:366 asdu (length: 5): 1049000000
19:11:34:395 APS-DATA.request id: 25, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 2 len: 5 tx.options 0x04
19:11:34:399 asdu (length: 5): 1039000E00
19:11:34:401 APS-DATA.confirm id: 21, status: 0x00 SUCCESS
19:11:34:403 APS-DATA.confirm request id: 21 -> erase from queue
19:11:34:434 aps request id: 21 finished, erase from queue
19:11:34:515 APS-DATA.confirm id: 24, status: 0x00 SUCCESS
19:11:34:516 APS-DATA.confirm request id: 24 -> erase from queue
19:11:34:545 APS-DATA.request id: 26, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 2 len: 5 tx.options 0x04
19:11:34:546 asdu (length: 5): 103A000040
19:11:34:547 APS-DATA.confirm id: 25, status: 0x00 SUCCESS
19:11:34:548 APS-DATA.confirm request id: 25 -> erase from queue
19:11:34:575 APS-DATA.indication srcAddr: 0x182E, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0008, lqi: 199, rssi: -66
19:11:34:578 asdu: 184901000000207c
19:11:34:581 APS-DATA.request id: 24 erase from queue
19:11:34:582 APS-DATA.request id: 25 erase from queue
19:11:34:585 APS-DATA.request id: 28, addrmode: 0x03, addr: 0x086BD7FFFE2545ED, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
19:11:34:586 asdu (length: 5): 104A000000
19:11:34:685 APS-DATA.request id: 30, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 2 len: 9 tx.options 0x04
19:11:34:686 asdu (length: 9): 103B00FDFFFEFF1000
19:11:34:687 APS-DATA.confirm id: 26, status: 0x00 SUCCESS
19:11:34:688 APS-DATA.confirm request id: 26 -> erase from queue
19:11:34:739 aps request id: 26 finished, erase from queue
19:11:34:795 APS-DATA.confirm id: 28, status: 0x00 SUCCESS
19:11:34:796 APS-DATA.confirm request id: 28 -> erase from queue
19:11:34:819 aps request id: 28 finished, erase from queue
19:11:34:842 APS-DATA.indication srcAddr: 0x182E, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 199, rssi: -66
19:11:34:845 asdu: 184a010000001000
19:11:34:872 APS-DATA.request id: 33, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 11 tx.options 0x04
19:11:34:875 asdu (length: 11): 103C001100120013001400
19:11:34:878 APS-DATA.confirm id: 30, status: 0x00 SUCCESS
19:11:34:880 APS-DATA.confirm request id: 30 -> erase from queue
19:11:34:909 aps request id: 30 finished, erase from queue
19:11:34:985 APS-DATA.request id: 34, addrmode: 0x02, addr: 0xF827, profile: 0x0104, cluster: 0x0000, ep: 0x01 -> 0x0B queue: 1 len: 11 tx.options 0x04
19:11:34:986 asdu (length: 11): 103D00DEFFE2FFE4FFFEFF
19:11:34:987 APS-DATA.confirm id: 33, status: 0x00 SUCCESS
19:11:34:988 APS-DATA.confirm request id: 33 -> erase from queue
19:11:35:059 aps request id: 33 finished, erase from queue
19:11:35:096 APS-DATA.request id: 36, addrmode: 0x03, addr: 0x000D6FFFFE904D7C, profile: 0x0104, cluster: 0x0300, ep: 0x01 -> 0x01 queue: 1 len: 5 tx.options 0x00
19:11:35:097 asdu (length: 5): 104B000700
19:11:35:185 APS-DATA.confirm id: 34, status: 0x00 SUCCESS
19:11:35:186 APS-DATA.confirm request id: 34 -> erase from queue
19:11:35:215 poll node 00:0b:57:ff:fe:eb:2f:84-01
19:11:35:216 Poll light node Panel Esszimmer
19:11:35:217 APS-DATA.confirm id: 36, status: 0x00 SUCCESS
19:11:35:220 APS-DATA.confirm request id: 36 -> erase from queue
19:11:35:256 aps request id: 34 finished, erase from queue
19:11:35:260 APS-DATA.indication srcAddr: 0x1FCF, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0300, lqi: 191, rssi: -67
19:11:35:262 asdu: 184b0107000021c601
19:11:35:264 APS-DATA.request id: 36 erase from queue
19:11:35:268 APS-DATA.request id: 38, addrmode: 0x03, addr: 0x000D6FFFFE904D7C, profile: 0x0104, cluster: 0x0008, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x00
19:11:35:270 asdu (length: 5): 104C000000
19:11:35:307 Poll APS request to 0x000B57FFFEEB2F84 cluster: 0x0006 dropped, values are fresh enough
19:11:35:375 APS-DATA.confirm id: 38, status: 0x00 SUCCESS
19:11:35:376 APS-DATA.confirm request id: 38 -> erase from queue
19:11:35:392 aps request id: 38 finished, erase from queue
19:11:35:418 APS-DATA.indication srcAddr: 0x1FCF, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0008, lqi: 191, rssi: -67
19:11:35:422 asdu: 184c01000000203c
19:11:35:427 APS-DATA.request id: 40, addrmode: 0x03, addr: 0x000D6FFFFE904D7C, profile: 0x0104, cluster: 0x0006, ep: 0x01 -> 0x01 queue: 0 len: 5 tx.options 0x00
19:11:35:429 asdu (length: 5): 104D000000
19:11:35:495 APS-DATA.confirm id: 40, status: 0x00 SUCCESS
19:11:35:496 APS-DATA.confirm request id: 40 -> erase from queue
19:11:35:525 APS-DATA.indication srcAddr: 0x1FCF, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0006, lqi: 191, rssi: -67
19:11:35:527 asdu: 184d010000001000
19:11:35:527 APS-DATA.request id: 40 erase from queue
Any idea what to try?
