Hi There
I’ ve just connected the deconz my new GLED controller GL-C-008P - so far recognized as a bulb. No problem with that, but I could NOT change any color nor brightness or whatever. Only on-off. Most probably I made seomthing wrong. Any ideas? Thank you - JJ
Can you change color using the rest api?
How can I check this?
Using the light endpoint on the rest api
Thanks - I’d try some more times and saw, that even when only the bulb is visible, I was able to double click on it and change some colors, looks to OK right now. JJ
