GiEX QT06 Water Timer
Hi, I’m new here. :wink:
I use a Conbee 2 on a rasp 4pi with different Sensors, Lights, …
Yesterday I found a new device:
GiEX QT06: ZIGBEE WIFI Garten Bewässerung Timer Smart Sprinkler Tropf Bewässerung System Gebaut in Wasser Fluss Recorder Wasser Controller TUYA| | - AliExpress
It uses zigbee, but I don’t know if it would be found as a device in phoscon without any extra hub?
Research doesn’t help. Found only this about the device:
GiEX Irrigation Valve QT06 Zigbee compatibility
Best
Udo
Think it could be the same that we’re experimenting integration here : GiEXperience SMART Water Valve (_TZE200_a7sghmms) · Issue #6944 · dresden-elektronik/deconz-rest-plugin · GitHub
OK, you are right. It seems already requested.
Hope to find it in phoscon soon.
Best
Udo
Moved to deconz general support.
