FYRTUR - /battery device is not created
I had to replace a broken FYRTUR with a new one. It had an old firmware installed and adding it via Phoscon did not work. After updating to the latest firmware I was able to add it via Phoscon and the lights API endpoint is there. But the battery endpoint is missing.
I tried paring it again, reading everything via deCONZ, reading the Power Configuration Cluster also works without problems. But no battery sensor is created
Another difference:
the old ones have "swversion": "24.4.13". The replacement has "swversion": "20190311". I updated to 24.4.13
Both are in the same DDF, I don’t see why can have only a part of the DDF.
You are looking directly in the API to be sure ? In phoscon/help/API Information/sensor ?
Yeah good idea, but the network need to be in permit join (“add new light” in Phoscon) in same time, to permit the device creation in API.
I tried reading everyting again while the network was open - no sensor was created. But the swversion is now correct.
I have 3 ZHABattery Sensors
curl -XGET http://.../api/.../sensors | jq '.[] | select(.type == "ZHABattery")' | grep uniqueid
  "uniqueid": "84:71:27:ff:fe:25:f7:b3-01-0001"
  "uniqueid": "84:fd:27:ff:fe:44:9b:ab-01-0001"
  "uniqueid": "00:21:2e:ff:ff:0c:73:67-01-0001"
(2x other FYRTUR, 1x Phoscon Hive)
but there is none for the newly added:
  "type": "Window covering device",
  "uniqueid": "68:0a:e2:ff:fe:f6:e3:bc-01"
curl -vv -XGET http://.../api/.../devices/68:0a:e2:ff:fe:f6:e3:bc | jq
  "lastannounced": "2024-07-10T09:25:55Z",
  "lastseen": "2024-07-11T05:19Z",
  "manufacturername": "IKEA of Sweden",
  "modelid": "FYRTUR block-out roller blind",
  "name": "Rollo DG Mika",
  "productid": "FYRTUR block-out roller blind",
        "alert": {
          "lastupdated": "2024-07-10T19:36:00Z",
          "value": null
        "bri": {
          "lastupdated": "2024-07-11T06:58:51Z",
          "value": 0
        "lift": {
          "value": 0
        "on": {
          "value": false
        "open": {
          "lastupdated": "2024-07-11T06:58:34Z",
          "value": true
        "reachable": {
          "value": true
  "swversion": "24.4.13",
  "uniqueid": "68:0a:e2:ff:fe:f6:e3:bc"
Which version of deCONZ is this?
The output of /devices/<mac address> should have a few more fields in current version.
Latest stable version
ii deconz 2.26.3 armhf Zigbee monitoring and control.
Just joined it freshly in our test network here with v2.27.4-beta, it creates the ZHABattery correctly.
However the unit has an older firmware SwBuildId 2.3.079.
I’ll check if OTA to newer version makes a difference.
Mine hat 2.2.x initially and this did not work at all (also no light created)
I made some screenshots for before and after comparison, wouldn’t be the first time that the descriptors are changed via OTA updates.
This will take a while, update is reaaaaly slow :slight_smile:
After OTA update to 24.4.13 the device still works.
In comparison the simple descriptor only got a new Identify client cluster (0x0003) but no changes which may cause troubles otherwise.
Note I’m testing with v2.27.4-beta not sure if that makes a difference.
The v2.26.3 still had the old Ikea blinds DDFs which where removed later on in favor for blinds.json DDF.
IDK if it’s linked but here Unable to pair Ikea PRAKTLYSING - #13 by drakkhen there is an user not able to pair a PRAKTLYSING.
On debug, deconz choose the good DDF, but nothing after.
pi@raspberrypi:~ $ sudo rm /usr/share/deCONZ/devices/ikea/fyrtur_block-out_roller_blind.json
pi@raspberrypi:~ $ sudo service deconz restart
opened the network and the sensor is there
    "alert": "none",
    "reachable": true
  "etag": "40b6bb78aa850767e46a6434ea5f5b58",
  "lastannounced": null,
  "lastseen": "2024-07-12T04:51Z",
  "name": "Rollo DG Mika (Akku)",
  "productid": "E1757-140",
    "battery": 97,
    "lastupdated": "2024-07-12T04:08:22.685"
  "type": "ZHABattery",
  "uniqueid": "68:0a:e2:ff:fe:f6:e3:bc-01-0001"
Good catch, also that the older files where intercepting loading of the blinds.json as they had Draft status.
I guess, we have a bug lurking that no two raw JSON files should exist using the same modelid/manufacturername, gonna need to check this.
Side note: For the new DDF bundles this isn’t a problem, loading here is based on embedded timestamps and stable/beta signature policies.
But this would kill the option to override existing “stock ddf” by simply putting it into /home/pi/.local/share/dresden-elektronik/deCONZ/devices/, right?
I’ve reported this before. I believe made a PR, but not sure what happened to it.
The PR is merged and works but that was after v2.26.3.
That stills works then, the two user/system locations are searched and user one takes priority.
