Does anybody has experience integrating this vibration sensor into phoscon?
I face 2 issues:
- The Sensor is not found during the normal “new Sensor” process
- There is no DDF to adjust the sensitivity, which is a key feature for me. I want to use it as a wind alarm for an awning.
I am willing to invest some work to do the integration but are there others who are interested in this sensor integration?
Smanar
2
There is no DDF for this device, but I m seing it use the cluster 0x0500 so can try to start with this DDF deconz-rest-plugin/devices/tuya/_TZ3000_TS0210_vibration_sensor.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
You will have issue for battery but the detection can work.
And yes it’s a presence detection, because the user that have make this DDF wanted to keep the same working mode.
