Fresh installed Domoticz crashes when adding deconz plugin
Describe the bug
Domoticz crashes when adding deconz plugin in its hardware
Domoticz logs:
021-11-25 22:27:15.404 Status: deconz zigbee bridge: (deconz zigbee bridge) Entering work loop.
2021-11-25 22:27:15.404 Status: deconz zigbee bridge: (deconz zigbee bridge) Started.
2021-11-25 22:27:16.407 deconz zigbee bridge: (deconz zigbee bridge) You are not using 127.0.0.1 as IP, so I suppose deCONZ and Domoticz aren’t on same machine
2021-11-25 22:27:16.407 deconz zigbee bridge: (deconz zigbee bridge) Taking 192.168.31.103 as Domoticz IP
2021-11-25 22:27:16.408 deconz zigbee bridge: (deconz zigbee bridge) Adding banned device : 00:15:8d:00:02:36:c2:3f-01-0500
2021-11-25 22:27:16.404 Status: deconz zigbee bridge: (deconz zigbee bridge) Initialized version 1.0.21, author ‘Smanar’
2021-11-25 22:27:18.127 Mysensor: Temp (Temp)
2021-11-25 22:27:25.077 Mysensor: Temp (Temp)
2021-11-25 22:27:25.080 deconz zigbee bridge: (deconz zigbee bridge) ### Request config
2021-11-25 22:27:25.186 Mysensor: Temp + Humidity (Sonde SDB)
2021-11-25 22:27:25.128 Status: deconz zigbee bridge: (deconz zigbee bridge) Firmware version: 0x26660700
2021-11-25 22:27:25.128 Status: deconz zigbee bridge: (deconz zigbee bridge) Websocketnotifyall: True
2021-11-25 22:27:25.129 Error: Domoticz(pid:564, tid:2047(‘deconz zigbee b’)) received fatal signal 11 (Segmentation fault)
2021-11-25 22:27:25.129 Error: siginfo address=0x234, address=(nil)
Steps to reproduce the problem
The OS (on which Domoticz is installed) is the last Raspberry OS running on a Raspberry 3B+.
The Domoticz is the last stable version.
The deconz gateway is running on a Raspberry Pi modèle B Rev. 2. Conbee II is plugged on USB port.
Phoscon is working well, I have 2 Aqara Temperature sensors paired.
I import manually my Database in Domoticz and restart it, everything is OK.
When I configure the Deconz plugin everything is OK.
When I enable the Deconz plugin in Domoticz Hardware, Domoticz crashes and is not reachable.
@Smanar
I made the same manipulations with an other fresh installation on a NanoPiM4 board.
domoticz@nanopim4:~/domoticz/plugins/Domoticz-deCONZ$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 21.04
Release: 21.04
Codename: hirsute
domoticz@nanopim4:~/domoticz/plugins/Domoticz-deCONZ$ arch
aarch64
The result is the same, at the end, when the plugin is enabled, Domoticz crashes and is not reachable anymore.
Hello, wich one python version are you using ?
It s your first python plugin ?
So you are using Domoticz V 2021.1 ?
This issue is generaly solved wich changing python or domoticz version (problem with pythn framework)
I made again a new fresh install with armbian focal:
domoticz@nanopim4:~$ lsb_release -a
Description: Ubuntu 20.04.3 LTS
Release: 20.04
Codename: focal
I am using Domoticz V 2021.1
Updating my python libraries to V3.8.
And miracle :slight_smile:
Now the question is: I have 3 separate indicators in Domoticz for an Aqara sensor and I woukd like to have THB on the same sensor. Is there a way to do that? Probably with Python/lua/dzvents scripts? Or an other easy way?
So all is fine with my nanopiM4 (the goal was to test the conbee II and the aqara sensors), however the final goal is to install all on my Raspberry Pi 3b+ and my problem is not solved for the moment.
pi@domoticz:~/domoticz/plugins/Domoticz-deCONZ $ pip3 show requests
Version: 2.25.1
Summary: Python HTTP for Humans.
Home-page: https://requests.readthedocs.io
Author: Kenneth Reitz
Author-email: me@kennethreitz.org
License: Apache 2.0
Requires:
Required-by:
pi@domoticz:~/domoticz/plugins/Domoticz-deCONZ $ python -V → Python 3.9.2
pi@domoticz:~/domoticz/plugins/Domoticz-deCONZ $ arch → armv7l
pi@domoticz:~/domoticz/plugins/Domoticz-deCONZ $ uname -mr → 5.10.63-v7+ armv7l
pi@domoticz:~/domoticz/plugins/Domoticz-deCONZ $ cat /etc/*release
PRETTY_NAME=“Raspbian GNU/Linux 11 (bullseye)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=“http://www.raspbian.org/”
SUPPORT_URL=“RaspbianForums - Raspbian”
BUG_REPORT_URL=“RaspbianBugs - Raspbian”
Domoticz version: 2021.1
Debug logs of Domoticz just before crashing:
2021-11-27 13:32:21.227 Status: bridge zigbee: (bridge zigbee) Entering work loop.
2021-11-27 13:32:21.227 Status: bridge zigbee: (bridge zigbee) Started.
2021-11-27 13:32:22.184 bridge zigbee: (bridge zigbee) You are not using 127.0.0.1 as IP, so I suppose deCONZ and Domoticz aren’t on same machine
2021-11-27 13:32:22.184 bridge zigbee: (bridge zigbee) Taking 192.168.31.103 as Domoticz IP
2021-11-27 13:32:22.184 bridge zigbee: (bridge zigbee) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE
2021-11-27 13:32:22.186 bridge zigbee: (bridge zigbee) Adding banned device : 00:15:8d:00:02:36:c2:3f-01-0500
2021-11-27 13:32:22.181 Status: bridge zigbee: (bridge zigbee) Initialized version 1.0.21, author ‘Smanar’
2021-11-27 13:32:31.055 bridge zigbee: (bridge zigbee) Pushing ‘onHeartbeatCallback’ on to queue
2021-11-27 13:32:31.106 (bridge zigbee) Processing ‘onHeartbeatCallback’ message
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) Calling message handler ‘onHeartbeat’.
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) onHeartbeat called
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) ### Initialisation > config
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) ### Request config
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) Send Command /api/E8C1667B1E/config/ with None (0 in buffer)
2021-11-27 13:32:31.106 bridge zigbee: (bridge zigbee) Making Request: http://192.168.31.102:80/api/E8C1667B1E/config/ with params None
2021-11-27 13:32:31.155 bridge zigbee: (bridge zigbee) Request Return: {“UTC”:“2021-11-27T12:32:31”,“apiversion”:“1.16.0”,“backup”:{“errorcode”:0,“status”:“idle”},“bridgeid”:“00212EFFFF07C2F5”,“datastoreversion”:“93”,“devicename”:“ConBee II”,“dhcp”:true,“disablePermitJoinAutoOff”:false,“factorynew”:false,“fwversion”:“0x26660700”,“gateway”:“192.168.31.1”,“internetservices”:{“internet”:“connected”,“remoteaccess”:“disconnected”,“swupdate”:“connected”,“time”:“connected”},“ipaddress”:“192.168.31.102”,“lightlastseeninterval”:60,“linkbutton”:true,“localtime”:“2021-11-27T12:32:31”,“mac”:“b8:27:eb:e3:33:ef”,“modelid”:“deCONZ”,“name”:“Phoscon-GW”,“netmask”:“255.255.255.0”,“networkopenduration”:180,“ntp”:“synced”,“panid”:24629,“portalconnection”:“disconnected”,“portalservices”:false,“portalstate”:{“communication”:“disconnected”,“incoming”:false,“outgoing”:false,“signedon”:false},“proxyaddress”:“none”,“proxyport”:0,“replacesbridgeid”:null,“rfconnected”:true,“starterkitid”:"",“swupdate”:{“checkforupdate”:false,“devicetypes”:{“bridge”:false,“lights”:[],“sensors”:[]},“notify”:false,“text”:"",“updatestate”:0,“url”:""},“swupdate2”:{“autoinstall”:{“on”:false,“updatetime”:""},“bridge”:{“lastinstall”:“2021-08-19T13:35:02”,“state”:“noupdates”},“checkforupdate”:false,“lastchange”:"",“state”:“noupdates”},“swversion”:“2.12.6”,“timeformat”:“24h”,“timezone”:“UTC”,“uuid”:“01bc8932-4e24-4109-84a7-ce726a0d8a6c”,“websocketnotifyall”:true,“websocketport”:443,“whitelist”:{“A3F5BCFE68”:{“create date”:“2021-11-27T12:32:01”,“last use date”:“2021-11-27T12:32:28”,“name”:“Phoscon#B1536x711”},“E8C1667B1E”:{“create date”:“2021-11-26T20:24:56”,“last use date”:“2021-11-27T12:32:31”,“name”:“Domoticz”}},“zigbeechannel”:11}
2021-11-27 13:32:31.157 bridge zigbee: (bridge zigbee) Classic Data : {‘UTC’: ‘2021-11-27T12:32:31’, ‘apiversion’: ‘1.16.0’, ‘backup’: {‘errorcode’: 0, ‘status’: ‘idle’}, ‘bridgeid’: ‘00212EFFFF07C2F5’, ‘datastoreversion’: ‘93’, ‘devicename’: ‘ConBee II’, ‘dhcp’: True, ‘disablePermitJoinAutoOff’: False, ‘factorynew’: False, ‘fwversion’: ‘0x26660700’, ‘gateway’: ‘192.168.31.1’, ‘internetservices’: {‘internet’: ‘connected’, ‘remoteaccess’: ‘disconnected’, ‘swupdate’: ‘connected’, ‘time’: ‘connected’}, ‘ipaddress’: ‘192.168.31.102’, ‘lightlastseeninterval’: 60, ‘linkbutton’: True, ‘localtime’: ‘2021-11-27T12:32:31’, ‘mac’: ‘b8:27:eb:e3:33:ef’, ‘modelid’: ‘deCONZ’, ‘name’: ‘Phoscon-GW’, ‘netmask’: ‘255.255.255.0’, ‘networkopenduration’: 180, ‘ntp’: ‘synced’, ‘panid’: 24629, ‘portalconnection’: ‘disconnected’, ‘portalservices’: False, ‘portalstate’: {‘communication’: ‘disconnected’, ‘incoming’: False, ‘outgoing’: False, ‘signedon’: False}, ‘proxyaddress’: ‘none’, ‘proxyport’: 0, ‘replacesbridgeid’: None, ‘rfconnected’: True, ‘starterkitid’: ‘’, ‘swupdate’: {‘checkforupdate’: False, ‘devicetypes’: {‘bridge’: False, ‘lights’: [], ‘sensors’: []}, ‘notify’: False, ‘text’: ‘’, ‘updatestate’: 0, ‘url’: ‘’}, ‘swupdate2’: {‘autoinstall’: {‘on’: False, ‘updatetime’: ‘’}, ‘bridge’: {‘lastinstall’: ‘2021-08-19T13:35:02’, ‘state’: ‘noupdates’}, ‘checkforupdate’: False, ‘lastchange’: ‘’, ‘state’: ‘noupdates’}, ‘swversion’: ‘2.12.6’, ‘timeformat’: ‘24h’, ‘timezone’: ‘UTC’, ‘uuid’: ‘01bc8932-4e24-4109-84a7-ce726a0d8a6c’, ‘websocketnotifyall’: True, ‘websocketport’: 443, ‘whitelist’: {‘A3F5BCFE68’: {‘create date’: ‘2021-11-27T12:32:01’, ‘last use date’: ‘2021-11-27T12:32:28’, ‘name’: ‘Phoscon#B1536x711’}, ‘E8C1667B1E’: {‘create date’: ‘2021-11-26T20:24:56’, ‘last use date’: ‘2021-11-27T12:32:31’, ‘name’: ‘Domoticz’}}, ‘zigbeechannel’: 11}
2021-11-27 13:32:31.157 Status: bridge zigbee: (bridge zigbee) Firmware version: 0x26660700
2021-11-27 13:32:31.157 Status: bridge zigbee: (bridge zigbee) Websocketnotifyall: True
2021-11-27 13:32:31.158 Error: Domoticz(pid:32201, tid:2714(‘bridge zigbee’)) received fatal signal 11 (Segmentation fault)
2021-11-27 13:32:31.158 Error: siginfo address=0x7dc9, address=(nil)
Yep it s possible using LUA, it s a long story, but I will not make mixed sensor from the python code itself https://github.com/Smanar/Domoticz-deCONZ/wiki/Example-to-make-a-LUA-script-to-mix-temperature-humidity-barometer-on-the-same-sensor
I m using too a raspberry 3, I have on my side
  • Domoticz version: 2021.1
  • Request version 2.21.0 (and yes this lib is one the libs that cause this issue)
  • python V 3.7.3
Perhaps because of bullseyes Domoticz crashes on pluginmanager after raspian bullseye update - Domoticz
sudo apt install libpython3.9-dev
Thx for your answers,
pi@domoticz:~ $ pi@domoticz:~ $ sudo apt install libpython3.9-dev
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
libpython3.9-dev is already the newest version (3.9.2-1+rpi1).
libpython3.9-dev set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
it seems also that Python 3.9 and Domoticz are not compatibles:
: Domoticz crashes on pluginmanager after raspian bullseye update
Post by PierreOV » Thursday 25 November 2021 22:39
I confirm the incompatibility Python 3.9 and Domoticz.
Back to Python 3.8 and working again
Yeah, have see it after, the “magic” they are using to make the connexion with c++ code / python code need to be updated.
It’s a realy frequent issue on domoticz. Need to take care before all updates, and sometime the rollback is not possible.
