FLS-M: Two Units No Longer Able to Power from VIN
I have two FLS-M units purchased this past spring which are no longer able to power from VIN.
  • Units power up if connected to computer via USB-C. I’m able to load firmware from, and flash to the device.
  • No lights, or Zigbee connectivity when powered via VIN (from 24v Meanwell PSU).
  • I’ve tried various resetting procedures (11000, etc), but nothing I’ve tried fixes this.
One of the devices experienced this issue while I was wiring for installation, it’s not impossible I accidentally reversed polarity, though that would be a first for me in many years of professional LED installation.
However, the 2nd device was installed and working for a few months before it stopped functioning.
I’ve reached out to support via email, but have not had a reply to my original email or follow-ups.
Our developers are trying to get to the bottom of the issue. You have also received an email.
I have a similar problem, I did recently buy the FLS-M and when connecting it to USB-C it works perfectly, I see the led (when connecting it to the zigbee network), I can flash it, read the configuration from flash, that all works. But when connected to VIN it does nothing, I tried 2 different power supplys, a 5V and a 12V but nothing changed.
Is the device broken? Do I send it back?
Regards,
Dirk
