Flashing Raspbee 2 not working
My Raspbee2 doesn’t connect to Deconz on my rpi. So I tried to update/flash it manually but I get an error: 1054: Error: (assert) n == CMD_deconzVersion.size().
Can somebody help me and tell what to do?
These are the logs:
hoobs@hoobs:~$ sudo systemctl stop deconz
[sudo] password for hoobs:
hoobs@hoobs:~$ wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF
–2022-06-26 14:24:20-- https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF
Resolving deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)… 144.76.96.194
Connecting to deconz.dresden-elektronik.de (deconz.dresden-elektronik.de)|144.76.96.194|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 163244 (159K) [application/octet-stream]
Saving to: ‘deCONZ_RaspBeeII_0x26780700.bin.GCF.1’
deCONZ_RaspBeeII_0x2678070 100%[=======================================>] 159.42K --.-KB/s in 0.06s
2022-06-26 14:24:20 (2.63 MB/s) - ‘deCONZ_RaspBeeII_0x26780700.bin.GCF.1’ saved [163244/163244]
hoobs@hoobs:~$ sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF
retry, failed
hoobs@hoobs:~$
Try it with a raspbian install and see if that works. I am not sure if there’s differences in hoobs their OS.
I did on a raspbian (native) install and it doesn’t work for connecting the raspbee nor for manually installing the firmware. Is there a way to check if the Raspbee2 is still working? If I check the RTC it works…
Can you share some deconz logs on the native install? In #deconz you can find out how to make logs.
Also, what Raspberry are you running? Did you do any changes recently? Are you using an ssd?
After re-enabling serial port hardware on rpi it worked! I am sure I did that before…
