I tried to update the firmware of a raspbee 2.
I followed the instruction on this site: Update deCONZ manually · dresden-elektronik/deconz-rest-plugin Wiki · GitHub
The update has been done on a Raspbian Buster Headless (from ConBee SD-card images )
The phoscon app was working and the raspbee ii was working before as well. I could control several devices.
The update said “failed retry”
Afterwards the phoscon app showed its not connected anymore. And the devices that worked previously are not working anymore.
I tried to update one more time ( also with an downgrade ) but its not working.
The version that should be installed was: deCONZ_ConBeeII_0x26780700.bin.GCF
I also doubled checked the wiring pi that it is version 2.52
The ouput now is:
lip put 0x4B
slip put 0x65
slip put 0xC0
action: reset device RaspBee
slip put 0xC0
slip put 0x81
slip put 0x02
slip put 0x7D
slip put 0xFF
slip put 0xC0
slip put 0xC0
slip put 0x81
slip put 0x02
slip put 0x7D
slip put 0xFF
slip put 0xC0
slip put 0xC0
slip put 0x81
slip put 0x02
slip put 0x7D
slip put 0xFF
slip put 0xC0
Output of: sudo GCFFlasher_internal -r
wiringPi 2.52 initialized
slip put 0xC0
slip put 0x81
slip put 0x02
slip put 0x7D
slip put 0xFF
slip put 0xC0
Bootloader version 0x00030003, app crc: 0x93C2CD88
pi@phoscon:/ $
GCFFlasher_internal -l
/dev/ttyS0 | 0x0000 | 0x0000 | | RaspBee
The gateway itself is working and shows the following information:
Hersteller: unknown
Produkt
Version 2.20.21 / 19.9.2022
Firmware: Nicht verbunden
Mimiix
January 21, 2023, 2:10pm
6
You try to use conbee firmware to update the raspbee. You need to use the raspbee firmware.
I tried it with the raspbee version first. But let me double check again.
Same Result but with way more slip put:
slip put 0xC0
retry, failed
pi@phoscon:~ $
Mimiix
January 21, 2023, 3:23pm
8
Can you please delete the big log?
What command do you use to start the update ?
So as I mentioned earlier I am using the headless Raspbian version.
I followed the instructions in this order:
sudo systemctl stop deconz
wget https://deconz.dresden-elektronik.de/deconz-firmware/deCONZ_RaspBeeII_0x26780700.bin.GCF
sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF
The hardware is properly connected as it was working before the firmware update.
Mimiix
January 21, 2023, 3:49pm
10
Can you add -x 3 as parameter ?
I executed this command: sudo GCFFlasher_internal -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF -x 3
I cant copy all of the result since the output is too long.
16:00:13:669 TX c08184000005000000017b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6af7b7ad7c401eab6aff562c0
16:00:13:670 SLIP RX frame length: 10
16:00:13:670 updateFirmwareV3DataRsp()
retry, failed
Mimiix
January 21, 2023, 5:21pm
13
@de_employees do you have any idea ?
Have you configured the UART correctly?
sudo raspi-config
Interfacing Options → Serial
Would you like a login shell accessible over serial? → No
Would you like the serial port hardware to be enabled? → Yes
And does the /boot/config.txt contains the following lines?
enable_uart=1
dtoverlay=pi3-miniuart-bt
I think the devicepath should then be /dev/ttyAMA0.
ChrisHae:
sudo raspi-config
the sudo raspi config is configured as you requested. The config files contains the following lines:
enable_uart=1
there was already
dtoverlay=pi3-miniuart-bt-overlay
I added
still the same issue with a lot of slip puts.
All of the mentioned lines are uncommented (without #)
dtoverlay=pi3-miniuart-bt-overlay should be ok. You don’t need the extra line from my post.
Could you please double check that deconz and deconz-gui is stoped by systemctl and also modemmanger is stopped sudo systemctl stop ModemManager before the update?
You could also try GCFFlasher v4 for the update:
You would need to checkout the repository and build the executable (GitHub - dresden-elektronik/gcfflasher: GCFFlasher is the tool to program the firmware of dresden elektronik's Zigbee products. )
I double checked that I stopped all the services. I will try the GCFFlasher v4 thank you. I will provide an update.
I cloned the repistory with git executed it with the following command and it worked, and I installed finally the latest firmware update
Thank you so much for the professional support!
I used the following command:
./GCFFlasher -t 60 -f deCONZ_RaspBeeII_0x26780700.bin.GCF
Glad it worked. I will forward this to our team so that they can check what the problem of the v3_17 GCFFlasher is.
Just being curious: where there also slip put output with GCFFlasher 4 ?
No there were no slip puts. It was quite short. You can see the complete output in the screenshot.
