Currently you can only identify a device by Manufactur Name and Model ID.
For example, Aqara has for their smart plugs different addresses for the power output within the same Model ID, so you can’t use both at the same time currently.
But, they fill other fields like 0x0001 (Application version) and 0x0006 (Date Code) (images attached to show the differences)
So, would it be possible to add optional identification options for Application Version and/or Date Code in case you have the same model but with different firmware?
Arf, cluster change, not sure using both will be possible in DDF.
And they have same cluster on both version ? Not possible to reconize them just with cluster list ?
IDK if the fingerprint used in DDF can be used as filter.
Ok. Can you re-read the active endpoints and the simple descriptors? Select the node and do a right click on it for that action. I’d expect the clusters to change.
done. 0x0B04 and 0x0702 were gone after re-read of simple descriptors. after a short time of 2-3 minutes they appeared again, so clusters are as before.
I’m not sure if this is completely true but I’m currently playing around with this device and I only get a permanent 0 on the Electrical Measurement cluster if the Zigbee coordinator responded with Xiaomi manufacturing codes on pairing.
It seems like that if the coordinator responds with 0x0 and 0x0, the active_power readout magically starts working. I’m guessing the ConBee responds with Xiaomi manufacturing codes for all Xiaomi devices? (Maybe try older ConBee firmware (without the E1 sensor patch) to see if that works for you.)
Also, the plug that reports the constant 0 for active power on the Electrical Measurement cluster: Which (special) endpoint, cluster, and attributes are used to get power consumption (+ special Xiaomi manufacturer code?)?
I would guess newer ConBee firmware versions also include a patch to respond with Xiaomi manufacturer codes (at least when a Xiaomi device is paired). However, to get proper behavior out of this plug, responding with other manufacturer codes on pairing, seems to do the trick.
nice catch about that manifacturing codes on pairing.
my older smart plug was indeed paired months ago with an older ConBee firmware, so it lacked the Lumi specific Cluster (0xFCC0). For me its not an issue to have active power not being updated, as I have an updated DDF for that plug that reads the xiaomi attributes and publishes them via api instead.
I’ve just re-paired the old one and now have the 0xFCC0 cluster to and it runs with my customized DDF, rather than with the default one.
One thing you just need to change is the reporting interval; thats with 5minutes too long for me, so I changed it to 30 (have this already done with the other smart plug without any issues).
