I was using my Raspbee running 26050500 for a couple of years. Recently my system started having issues with the ZigBee setup. I updated from a Pi 3 to a Pi 4 as I assumed the load would be the issue (1 GB of RAM which was full all the time). The new setup worked fine, but would only last for a day until it needed a restart.
I’m trying to update to a more recent firmware (26400500). I am following Update deCONZ manually · dresden-elektronik/deconz-rest-plugin Wiki · GitHub and set up a dedicated Pi 3 with “Raspbian Buster Desktop” from SD-cart images. The phoscon app successfully connects to the Raspbee (though no lights are configured in the temporary installation). But the GCFFlasher_internal seems to be stuck at “query bootloader id V1” which it will print forever:
pi@phoscon:~ $ sudo GCFFlasher_internal -t 60 -d /dev/serial0 -f deCONZ_Rpi_0x26400500.bin.GCF
read file success: deCONZ_Rpi_0x26400500.bin.GCF (127664 bytes)
flash firmware
command UART reset done
query bootloader failed
retry: 54 seconds left
flash firmware
And querying the available devices (when deconz and deconz-gui are stopped) also fails:
pi@phoscon:~ $ sudo GCFFlasher_internal -l -x 3 -d /dev/serial0
no devices found
Path | Serial | Type
Is the device damaged? Or am I missing something?
