Hi all,
Haven’t been able to find any solution to this issue - hope someone can help.
Using Debian 12
Since I have updated to Deconz 2.32.1 TCP connections that are opened by deconz continues to rise until the service stops responding with 100% CPU and max open files is reached.
sudo lsof -p 637 | grep -i ipv4 | wc -l
Shows currently 693, this is with 6:39h system uptime, and the number of connections continues to rise.
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
deCONZ 637 jakob 17u IPv4 209844 0t0 TCP localhost:60864->localhost:8001 (ESTABLISHED)
deCONZ 637 jakob 18u IPv4 212351 0t0 TCP localhost:8001->localhost:60864 (ESTABLISHED)
deCONZ 637 jakob 19u IPv4 562022 0t0 TCP localhost:56350->localhost:8001 (ESTABLISHED)
deCONZ 637 jakob 20u IPv4 562193 0t0 TCP localhost:8001->localhost:56350 (ESTABLISHED)
deCONZ 637 jakob 21u IPv4 614257 0t0 TCP localhost:34040->localhost:8001 (ESTABLISHED)
deCONZ 637 jakob 22u IPv4 617172 0t0 TCP localhost:8001->localhost:34040 (ESTABLISHED)
deCONZ 637 jakob 23u IPv4 680347 0t0 TCP localhost:43038->localhost:8001 (ESTABLISHED)
deCONZ 637 jakob 24u IPv4 614259 0t0 TCP localhost:34054->localhost:8001 (ESTABLISHED)
deCONZ 637 jakob 25u IPv4 617174 0t0 TCP localhost:8001->localhost:34054 (ESTABLISHED)
deCONZ 637 jakob 26u IPv4 683093 0t0 TCP localhost:8001->localhost:43038 (ESTABLISHED)
Deconz journalctl log:
-- Boot 176c8888b4f943979ad35a613179822d --
Nov 24 14:54:47 GIR deCONZ[637]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-jakob'
Nov 24 14:54:47 GIR deCONZ[637]: libpng warning: iCCP: known incorrect sRGB profile
Nov 24 14:54:47 GIR deCONZ[637]: This plugin does not support propagateSizeHints()
Nov 24 14:54:50 GIR deCONZ[637]: This plugin does not support propagateSizeHints()
Any suggestions are welcome ![]()
