I am using the HA addon for this, I can see the items in deConz but they just wont pair.
I have 2 x Motion Sensors and 1 zigbee button, they show in deconz but when I put them to pair and try and detect a switch or sensor in Phoscon it just goes through for 3 minutes and times out.
Hello, all seem fine, can you give your deconz version and the modelid/ManufactureName of devices ?
Visible on the cluster 0x0000 or the “info” panel.
Remember for sensor you can need to “awake” the device in same time.
The devices are not supported in your version and thus not in phoscon.
I recommend checking the model id / manufacturer name in deconz and match that with GitHub to see if it’s actually supported but in a later version or not all.
