Device request Phoscon: YNOA wireless dimmer switch
Looking for a wireless dimmer switch with turn knob and found this one.
Info I’ve got is;
Model LA-AAN-UIT-7A
ID ZBT-DIMSwitch-D000
EAN 8718801528334
Where can I find if this product is compatible with deconz? The product is supposed to work with ZIGBEE2MQTT.
You can find the lists for compatible devices on our homepage: Compatibility
Unfortunately, YNOA means nothing to me at all. I could not find anything on Blackadder either. Probably a device request would have to be created: [Read Me] Device request read me
@edwin2023 Can you share the link from Z2m?
Would this be helpful?
I want to purchase two of these but want to make sure they will work :wink:
Thw wife part would be very happy…
Note that the Phoscon list is not up-to date. General thumb of rule is to search github issues for the Manufacturer name / Model ID.
I have did so, but failed to find this device supported @edwin2023 . However, support should be easy to add with DDF’s.
I purchased one with extended return privilege.
Together with a philips bulb master value e27 Ean 242494 and a dim/switch Adorosmart Erica 200W zigbee (Ean 0852263008640) from robbshop.nl for testing purposes. As soon they arrive I will test and come back.
If it doesn’t work out of the box, you should open device requests as Gautama linked.
Device request opened
Device name #6939
I would love to have a bit help on github with the ddf and log part :wink:
@Smanar is already helping you on that device request, what kind of other help do you need ?
Best to keep any chat in that GitHub issue :slight_smile:
Alright, I’ll stay in github until it’s working
Oh as we have this issue here, i’ll move it to the Phoscon area.
@de_employees Request is to have this supported in Phoscon too as we have it working in deCONZ.
@mimixx. Thnx!
When could I expect this device working in phoscon app, any time frame?
1 and ??? months. Phoscon is never quick with developments. Haven’t seen a lot of changes in the past years. I wouldn’t put my hopes up and search other methods. For example, use Hue Essentials to map the buttons using Rules in deCONZ.
Not really for me, I use Homeseer. So for me it’s almost solved, have to figure out long press for dimming.
I’m able to use the button. It’s just for others
