Yes, I did (smartphone & PC). Now it’s only the PC (192.168.178.83)
21:46:38:437 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571370 - 192.168.178.83
21:46:38:438 ApiMode: 0
21:46:38:438 {“lastscan”:“active”}
21:46:38:481 APS-DATA.request id: 47, addrmode: 0x02, addr: 0xfffc, profile: 0x0000, cluster: 0x0036, ep: 0x00 → 0x00 queue: 1
len: 3 tx.options 0x00
21:46:38:481 send permit join, duration: 59
21:46:38:482 APS-DATA.request id: 48, addrmode: 0x02, addr: 0xfffc, profile: 0xA1E0, cluster: 0x0021, ep: 0xF2 → 0xF2 queue: 2
len: 6 tx.options 0x00
21:46:38:522 APS-DATA.confirm id: 47, status: 0x00 SUCCESS
21:46:38:561 aps request id: 47 finished, erase from queue
21:46:38:583 APS-DATA.confirm id: 48, status: 0x00 SUCCESS
21:46:38:641 aps request id: 48 finished, erase from queue
21:46:38:802 Node 0x00158D0003FB4BD1 is known by 0 neighbors, last seen 0 s
21:46:38:939 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571371 - 192.168.178.83
21:46:38:940 ApiMode: 0
21:46:38:941 {“lastscan”:“active”}
21:46:39:282 Node 0x00158D000418D6DC is known by 0 neighbors, last seen 0 s
21:46:39:441 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571372 - 192.168.178.83
21:46:39:442 ApiMode: 0
21:46:39:442 {“lastscan”:“active”}
21:46:39:761 Node 0x00158D00045C9D5D is known by 0 neighbors, last seen 0 s
21:46:39:942 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571373 - 192.168.178.83
21:46:39:943 ApiMode: 0
21:46:39:944 {“lastscan”:“active”}
21:46:39:001 Mgmt_Lqi_req zdpSeq: 5 to 0x00158D0003893FCA start index 0
21:46:39:002 APS-DATA.request id: 56, addrmode: 0x03, addr: 0x00158d0003893fca, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0
x00 queue: 1 len: 2 tx.options 0x00
21:46:40:015 APS-DATA.confirm id: 56, status: 0x00 SUCCESS
21:46:40:016 APS-DATA.confirm request id: 56 → confirmed, timeout 306137022
21:46:40:031 APS-DATA.indication srcAddr: 0xe349, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 39, rssi:
-89
21:46:40:031 asdu: 0500050002c84b05ffff2e2100c84b05ffff2e2100000004020003c84b05ffff2e2100cdb2d0feff277184e89c1202021e
21:46:40:032 APS-DATA.indication request id: 56 → finished
21:46:40:033 APS-DATA.request id: 56 erase from queue
21:46:40:033 ZDP status = 0x00 → SUCCESS
21:46:40:034 ZDP Mgmt_Lqi_rsp zdpSeq: 5 from 0x00158D0003893FCA total: 5, startIndex: 0, listCount: 2
21:46:40:034 * neighbor: 0x00212EFFFF054BC8 (0x0000), LQI: 3, relation: 0x00 rxOnWHenIdle: 1
21:46:40:035 * neighbor: 0x847127FFFED0B2CD (0x9CE8), LQI: 30, relation: 0x01 rxOnWHenIdle: 0
21:46:40:241 Node 0x00158D0003FB4BF4 is known by 0 neighbors, last seen 0 s
21:46:40:443 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571374 - 192.168.178.83
21:46:40:444 ApiMode: 0
21:46:40:445 {“lastscan”:“active”}
21:46:40:485 HTTP API GET /api/config - 127.0.0.1
21:46:40:486 {“apiversion”:“1.16.0”,“bridgeid”:“00212EFFFF054BC8”,“datastoreversion”:“93”,“devicename”:“ConBee II”,“factorynew”
:false,“mac”:“dc:a6:32:4f:43:7f”,“modelid”:“deCONZ”,“name”:“Raspberry-GW”,“replacesbridgeid”:null,“starterkitid”:"",“swversion”
:“2.12.6”}
21:46:40:721 Node 0x00158D0003FB4D10 is known by 0 neighbors, last seen 0 s
21:46:40:943 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571375 - 192.168.178.83
21:46:40:944 ApiMode: 0
21:46:40:944 {“lastscan”:“active”}
21:46:41:201 Node 0x847127FFFED0B2CD is known by 1 neighbors, last seen 1089 s
21:46:41:444 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571376 - 192.168.178.83
21:46:41:445 ApiMode: 0
21:46:41:445 {“lastscan”:“active”}
21:46:41:609 HTTP API GET /api/38D7042DC3/sensors?=1637707571377 - 192.168.178.83
21:46:41:610 ApiMode: 0
21:46:41:682 Node 0x00158D000465B84A is known by 0 neighbors, last seen 0 s
21:46:41:945 HTTP API GET /api/38D7042DC3/sensors/new?_=1637707571378 - 192.168.178.83
21:46:41:946 ApiMode: 0
21:46:41:946 {“lastscan”:“active”}
21:46:42:162 Node 0x00158D0003FB4B72 is known by 0 neighbors, last seen 0 s
21:46:42:430 M-SEARCH * HTTP/1.1
HOST: 239.255.255.250:1900
MAN: “ssdp:discover”
MX: 1
ST: urn:dial-multiscreen-org:service:dial:1
USER-AGENT: Google Chrome/95.0.4638.69 Linux
21:46:42:447 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571379 - 192.168.178.83
21:46:42:447 ApiMode: 0
21:46:42:447 {“lastscan”:“active”}
21:46:42:641 Node 0x00158D0003FB4D00 is known by 0 neighbors, last seen 0 s
21:46:42:881 Mgmt_Lqi_req zdpSeq: 6 to 0x00158D0003893FCA start index 2
21:46:42:882 APS-DATA.request id: 69, addrmode: 0x03, addr: 0x00158d0003893fca, profile: 0x0000, cluster: 0x0031, ep: 0x00 → 0x00 queue: 1 len: 2 tx.options 0x00
21:46:42:892 APS-DATA.confirm id: 69, status: 0x00 SUCCESS
21:46:42:892 APS-DATA.confirm request id: 69 → confirmed, timeout 306139901
21:46:42:906 APS-DATA.indication srcAddr: 0xe349, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8031, lqi: 39, rssi: -89
21:46:42:907 asdu: 0600050202c84b05ffff2e210095c47b04008d15008fcd12020280c84b05ffff2e2100d14bfb03008d1500a94d12020273
21:46:42:907 APS-DATA.indication request id: 69 → finished
21:46:42:907 APS-DATA.request id: 69 erase from queue
21:46:42:907 ZDP status = 0x00 → SUCCESS
21:46:42:908 ZDP Mgmt_Lqi_rsp zdpSeq: 6 from 0x00158D0003893FCA total: 5, startIndex: 2, listCount: 2
21:46:42:908 * neighbor: 0x00158D0003FB4BD1 (0x4DA9), LQI: 115, relation: 0x01 rxOnWHenIdle: 0
21:46:42:948 HTTP API GET /api/38D7042DC3/sensors/new?=1637707571380 - 192.168.178.83
21:46:42:948 ApiMode: 0
21:46:42:949 {“lastscan”:“active”}
21:46:43:121 Node 0x00158D0003FB4BD2 is known by 0 neighbors, last seen 0 s
21:46:43:431 M-SEARCH * HTTP/1.1
MX: 1
21:46:43:450 HTTP API GET /api/38D7042DC3/sensors/new?_=1637707571381 - 192.168.178.83
21:46:43:450 ApiMode: 0
21:46:43:451 {“lastscan”:“active”}
21:46:43:601 Node 0x00158D00047BC495 is known by 1 neighbors, last seen 614 s
21:46:43:743 APS-DATA.indication srcAddr: 0xe349, srcEp: 0x01 dstAddrMode: 2, profile: 0x0104, cluster: 0x0B04, lqi: 47, rssi:
-88
21:46:43:744 asdu: 18e80a0b05290000
21:46:43:744 Node data 0x00158d0003893fca profileId: 0x0104, clusterId: 0x0B04
21:46:43:745 0x00158D0003893FCA: added ZCL value 0x01/0x0B04/0x050B
21:46:43:745 [INFO] - No button map for: SP 120, unicast to: 0x0000, endpoint: 0x01, cluster: 0x0B04, command: 0x0A, payload: 0
B05290000, zclSeq: 232
21:46:43:746 ZCL attribute report 0x00158D0003893FCA for cluster: 0x0B04, ep: 0x01, frame control: 0x18, mfcode: 0x0000
21:46:43:746 payload: 0b05290000
21:46:43:746 0x00158D0003893FCA (SP 120) create binding for attribute reporting of cluster 0x0702 on endpoint 0x01
21:46:43:747 queue binding task for 0x00158D0003893FCA, cluster 0x0702
21:46:43:747 binding for attribute reporting of ep: 0x01 cluster 0x0B04 seems to be active
21:46:43:748 Websocket 192.168.178.83:38770 send message: {“e”:“changed”,“id”:“3”,“r”:“sensors”,“state”:{“current”:0,“lastupdat
ed”:“2021-11-23T22:46:43.745”,“power”:0,“voltage”:234},“t”:“event”,“uniqueid”:“00:15:8d:00:03:89:3f:ca-01-0b04”} (ret = 181)
21:46:43:748 APS-DATA.request id: 76, addrmode: 0x03, addr: 0x00158d0003893fca, profile: 0x0000, cluster: 0x0021, ep: 0x00 → 0
x00 queue: 1 len: 22 tx.options 0x04
21:46:43:753 HTTP API GET /api/38D7042DC3/sensors/3 - 192.168.178.83
21:46:43:753 ApiMode: 0
21:46:43:754 {“config”:{“on”:true,“reachable”:true},“ep”:1,“etag”:“e38e89f711c2205da78759ea57349173”,“lastannounced”:null,“last
seen”:“2021-11-23T20:01Z”,“manufacturername”:“innr”,“modelid”:“SP 120”,“name”:“Power 3”,“state”:{“current”:0,“lastupdated”:“202
1-11-23T22:46:43.745”,“power”:0,“voltage”:234},“swversion”:“2.0”,“type”:“ZHAPower”,“uniqueid”:“00:15:8d:00:03:89:3f:ca-01-0b04”
21:46:43:769 APS-DATA.confirm id: 76, status: 0x00 SUCCESS
21:46:43:770 APS-DATA.confirm request id: 76 → confirmed, timeout 306140768
21:46:43:787 APS-DATA.indication srcAddr: 0xe349, srcEp: 0x00 dstAddrMode: 2, profile: 0x0000, cluster: 0x8021, lqi: 39, rssi:
-89
21:46:43:788 asdu: 6f00
