Number of ampere (or mA depending of device) used by the load.
And as power = voltage * current, with a power = 1 W I think your device use realy few current, so can explan the zero value.
So All is fine, I can make a PR to submit the DDF or do you want to make it yourself ?
I’ll let you do the PR because I wouldn’t want it rejected again.
@Smanar, thanks a lot for your help.
@monpelaud I have updated the DDF on the PR.
Can you test it again ? I have updated the state/consumption, I was using same value for power and consumption previously.
@Smanar Ok, I’ll do a test with the new DDF file. I will post the logs as soon as possible.
@Smanar, here are the REST API logs:
"2": {
"capabilities": {
"alerts": [
"none",
"select",
"lselect"
"groups": []
"etag": "6244fac1db39c3b00568aaa844c6f9be",
"hascolor": false,
"lastannounced": "2023-03-01T21:08:22Z",
"lastseen": "2023-03-01T21:18Z",
"manufacturername": "LUMI",
"modelid": "lumi.relay.c2acn01",
"name": "On/Off output 2",
"alert": "none",
"on": false,
"reachable": true
"swversion": "0.0.0_0036",
"type": "On/Off output",
"uniqueid": "00:15:8d:00:07:9b:88:e1-01"
"3": {
"capabilities": {
"alerts": [
"none",
"select",
"lselect"
"groups": []
"etag": "9d04079e1a5e48f79b87fa8cb8d92720",
"hascolor": false,
"name": "On/Off output 3",
"alert": "none",
"on": false,
"reachable": true
"uniqueid": "00:15:8d:00:07:9b:88:e1-02"
"14": {
"reachable": true,
"temperature": null
"etag": "2a0bfd7c8f6aa5d44e28582ab038bba6",
"name": "Consumption 14",
"consumption": 0,
"lastupdated": "2023-03-01T21:14:49.349"
"type": "ZHAConsumption",
"uniqueid": "00:15:8d:00:07:9b:88:e1-01-000c"
"15": {
"reachable": true,
"temperature": null
"etag": "c31840b29bd6546aa012aae360e3173a",
"lastseen": "2023-03-01T21:17Z",
"name": "Power 15",
"current": 0,
"lastupdated": "2023-03-01T21:17:34.351",
"power": 0,
"voltage": 239
"type": "ZHAPower",
"uniqueid": "00:15:8d:00:07:9b:88:e1-01-0b04"
here are the Events logs:
"21:14:49:354": {
"attr": {
"id": "15",
"lastseen": "2023-03-01T21:14Z",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:14:49:360": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:14:49.346",
"power": 0,
"voltage": 239
"t": "event",
"21:14:49:362": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:14:49:365": {
"e": "changed",
"id": "14",
"r": "sensors",
"consumption": 0,
"t": "event",
"21:14:57:404": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:14:57.401",
"power": 0,
"voltage": 239
"t": "event",
"21:14:57:774": {
"attr": {
"id": "15",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:14:57:779": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:14:57:961": {
"attr": {
"id": "15",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:14:57:964": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:15:20:339": {
"attr": {
"id": "2",
"lastseen": "2023-03-01T21:15Z",
"e": "changed",
"id": "2",
"r": "lights",
"t": "event",
"21:15:20:343": {
"attr": {
"id": "3",
"e": "changed",
"id": "3",
"r": "lights",
"t": "event",
"21:15:20:346": {
"attr": {
"id": "15",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:15:20:349": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:15:47:888": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:15:47.884",
"power": 0,
"voltage": 239
"t": "event",
"21:16:20:359": {
"attr": {
"id": "2",
"lastseen": "2023-03-01T21:16Z",
"e": "changed",
"id": "2",
"r": "lights",
"t": "event",
"21:16:20:363": {
"attr": {
"id": "3",
"e": "changed",
"id": "3",
"r": "lights",
"t": "event",
"21:16:20:367": {
"attr": {
"id": "15",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:16:20:370": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:16:36:344": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:16:36.341",
"power": 8,
"voltage": 239
"t": "event",
"21:16:38:344": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:16:38.341",
"power": 11,
"voltage": 239
"t": "event",
"21:16:42:344": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:16:42.341",
"power": 9,
"voltage": 239
"t": "event",
"21:16:44:349": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:16:44.344",
"power": 6,
"voltage": 239
"t": "event",
"21:16:58:400": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:16:58.394",
"power": 10,
"voltage": 239
"t": "event",
"21:17:04:354": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:17:04.351",
"power": 0,
"voltage": 239
"t": "event",
"21:17:12:349": {
"e": "changed",
"id": "15",
"r": "sensors",
"current": 0,
"lastupdated": "2023-03-01T21:17:12.344",
"power": 3,
"voltage": 239
"t": "event",
"21:17:20:360": {
"attr": {
"id": "2",
"e": "changed",
"id": "2",
"r": "lights",
"t": "event",
"21:17:20:363": {
"attr": {
"id": "3",
"e": "changed",
"id": "3",
"r": "lights",
"t": "event",
"21:17:20:366": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
"21:17:32:545": {
"attr": {
"id": "15",
"name": "Power 15",
"type": "ZHAPower",
"e": "changed",
"id": "15",
"r": "sensors",
"t": "event",
"21:18:20:374": {
"attr": {
"id": "2",
"e": "changed",
"id": "2",
"r": "lights",
"t": "event",
"21:18:20:380": {
"attr": {
"id": "3",
"e": "changed",
"id": "3",
"r": "lights",
"t": "event",
"21:18:20:384": {
"attr": {
"id": "14",
"e": "changed",
"id": "14",
"r": "sensors",
"t": "event",
What is strange is that only the “power” value changes, the “current” and “consumption” values always remain at 0!
Yeah, it’s worrying but current need to work, perhaps not enought consumption, perhaps a convertion issue (need to use mA, but it’s perhaps Ampere). Do you have a device with more consumption ? like a vaccum ?
The relay only controls the contactor of a pump, which explains the low consumption reported by the relay.
Ha yes, so can be normal, the current is the same code used on another device, so I think it’s fine, my problem is for the consumption, and I realy have no clue how it work for this device.
Consumption is not computed by Phoscon?
Consumption = Power * Time
No by the device.
With the new DDF, I see something that surprises me.
The relay has 2 channels and I see the definition of two “ZHAPower” type entities and one “ZHAConsumption” type entity.
I don’t understand why the two “ZHAPower” type entities don’t have the same structure?
The entity of type “ZHAConsumption” being unique I suppose that it is the sum of the two channels?
"47": {
"reachable": true,
"temperature": null
"etag": "68272107754d9ac2364a610f362b862c",
"lastannounced": "2023-04-04T18:00:48Z",
"lastseen": "2023-04-09T09:51Z",
"name": "Consumption 47",
"consumption": null,
"current": 5,
"lastupdated": "2023-04-09T09:51:56.013",
"power": 1066,
"voltage": 238
"type": "ZHAPower",
"48": {
"reachable": true,
"temperature": null
"etag": "8ead5add95c130943471b924a985dae7",
"name": "Power 48",
"current": null,
"lastupdated": "2023-04-09T09:52:20.665",
"power": -1,
"voltage": null
"type": "ZHAPower",
"49": {
"reachable": true,
"temperature": null
"etag": "1a85cd613eefd32d4dc3f35ba2355454",
"name": "Consumption 49",
"consumption": 0,
"lastupdated": "2023-04-09T09:51:56.121"
"uniqueid": "00:15:8d:00:07:9b:88:e1-01-0702"
Yes, this is normal, nope ?
"type": "ZHAPower",
"type": "ZHAPower",
Here we have a problem ^^. The second ZHAPower is not visible on the DDF, IDK where it is from …
Can come from legacy code, you have deleted the device before adding the DDF ?
you are right, I erased the device from Phoscon before adding it again and I get these new definitions:
"50": {
"reachable": true,
"temperature": null
"etag": "1f664b1f2b89a78b9b5774d70ea88e16",
"lastannounced": null,
"lastseen": "2023-04-19T17:21Z",
"name": "Consumption 50",
"current": 0,
"lastupdated": "2023-04-19T17:20:48.419",
"power": 2,
"voltage": 239
"type": "ZHAPower",
"51": {
"reachable": true,
"temperature": 0
"etag": "73491bc7614fd8b02604df0c18f5b6da",
"lastannounced": "2023-04-19T15:50:17Z",
"name": "Power 51",
"current": 0,
"lastupdated": "2023-04-19T17:21:08.762",
"power": -1,
"voltage": 0
"type": "ZHAPower",
"52": {
"reachable": true,
"temperature": null
"etag": "e3d5f6223c4021becafaa8545b0b52c2",
"name": "Consumption 52",
"consumption": 0,
"lastupdated": "2023-04-19T17:20:09.732"
In “50:” “ZHAPower” I see “voltage”: 239 but I dont find this voltage value (239 volts) in deCONZ!
In home Assistant, I see “Power 51.power”: -1 but not “Power 51.voltage”: 239.
In Home Assistant I was hoping to find “Power 51.voltage”: 239 V instead of “Power 51.power”: -1 W.
Same issue, you have again the “ghost” sensor
This one is not in the DDF.
You are it’s the good DDF used by deconz ? You can check it using the GUI, “edit DDF”, the good one is this one deconz-rest-plugin/xiaomi_lumi.relay.c2acn01.json at master · dresden-elektronik/deconz-rest-plugin · GitHub
@Smanar
I am using deCONZ v2.21.2 via Home Assistant plugin at its latest version with deCONZ v2.21.2.
I am surprised because the 2 DDF files are not the same! I thought the built-in DDF file in deCONZ version 2.21.2 was the new DDF!
Can you confirm that the next stable version of deCONZ will integrate the new DDF?
Here my DDF file:
“manufacturername”: “$MF_LUMI”,
“modelid”: “lumi.relay.c2acn01”,
“product”: “wireless relay with neutral”,
“sleeper”: false,
“status”: “Silver”,
“path”: “/devices/xiaomi/xiaomi_lumi.relay.c2acn01.json”,
“subdevices”: [
“type”: “$TYPE_ON_OFF_OUTPUT”,
“restapi”: “/lights”,
“uuid”: [
“$address.ext”,
“0x01”
“items”: [
“name”: “attr/id”
“name”: “attr/lastannounced”
“name”: “attr/lastseen”
“name”: “attr/manufacturername”
“name”: “attr/modelid”
“name”: “attr/name”
“name”: “attr/swversion”
“name”: “attr/type”
“name”: “attr/uniqueid”
“name”: “state/alert”,
“default”: “none”
“name”: “state/on”,
“refresh.interval”: 360
“name”: “state/reachable”
“uuid”: [
“$address.ext”,
“0x02”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/type”
“default”: “none”
“name”: “state/on”,
“type”: “$TYPE_POWER_SENSOR”,
“restapi”: “/sensors”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x000C”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/type”
“name”: “config/on”
“name”: “config/reachable”
“name”: “config/temperature”
“name”: “state/current”,
“refresh.interval”: 300,
“read”: {
“fn”: “none”
“parse”: {
“at”: “0x00F7”,
“eval”: “Item.val = Math.round(Attr.val);”,
“fn”: “xiaomi:special”,
“idx”: “0x97”
“default”: 0
“name”: “state/lastupdated”
“name”: “state/power”,
“refresh.interval”: 360,
“read”: {
“at”: “0x0055”,
“cl”: “0x000C”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x0055”,
“cl”: “0x000C”,
“ep”: 1,
“default”: 0
“name”: “state/voltage”,
“read”: {
“fn”: “none”
“parse”: {
“at”: “0x00F7”,
“eval”: “Item.val = Math.round(Attr.val / 10);”,
“idx”: “0x96”
“default”: 0
“type”: “$TYPE_CONSUMPTION_SENSOR”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x0702”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/type”
“name”: “config/on”
“name”: “state/consumption”,
“read”: {
“fn”: “none”
“parse”: {
“at”: “0x00f7”,
“idx”: “0x95”
“default”: 0
“bindings”: [
“bind”: “unicast”,
“src.ep”: 1,
“dst.ep”: 1,
“cl”: “0x0006”,
“report”: [
“at”: “0x0000”,
“dt”: “0x10”,
“min”: 5,
“max”: 300
“bind”: “unicast”,
“src.ep”: 2,
“dst.ep”: 1,
“cl”: “0x0006”,
“report”: [
“at”: “0x0000”,
“dt”: “0x10”,
“min”: 5,
“max”: 300
There is a difference on the DDF ? For me they are looking same.
On your DDF too you haven’t code to create a sensor on cluster 0x0b04.
No, the two DDFs are not the same, my DDF has 296 lines while in github the DDF has 330 lines.
Here DDF in github:
“sleeper”: false,
“status”: “Silver”,
“subdevices”: [
“uuid”: [
“$address.ext”,
“0x01”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“name”: “attr/swversion”,
“awake”: true,
“parse”: {
“at”: “0x00f7”,
“ep”: 1,
“idx”: “0x08”,
“script”: “xiaomi_swversion.js”
“read”: {
“fn”: “none”
“name”: “attr/type”
“name”: “state/on”,
“uuid”: [
“$address.ext”,
“0x02”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“awake”: true,
“parse”: {
“at”: “0x00f7”,
“ep”: 1,
“idx”: “0x08”,
“read”: {
“fn”: “none”
“name”: “attr/type”
“name”: “state/on”,
“uuid”: [
“$address.ext”,
“0x01”,
“0x000C”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“awake”: true,
“parse”: {
“at”: “0x00f7”,
“ep”: 1,
“idx”: “0x08”,
“read”: {
“fn”: “none”
“name”: “attr/type”
“name”: “config/on”
“parse”: {
“at”: “0x00F7”,
“idx”: “0x97”
“read”: {
“fn”: “none”
“refresh.interval”:360,
“read”: {
“at”: “0x0055”,
“cl”: “0x000C”,
“ep”: 1,
“fn”: “zcl”
“parse”: {
“at”: “0x0055”,
“cl”: “0x000C”,
“ep”: 1,
“parse”: {
“at”: “0x00F7”,
“idx”: “0x96”
“read”: {
“fn”: “none”
“uuid”: [
“$address.ext”,
“0x01”,
“0x0702”
“items”: [
“name”: “attr/id”
“name”: “attr/name”
“awake”: true,
“parse”: {
“at”: “0x00f7”,
“ep”: 1,
“idx”: “0x08”,
“read”: {
“fn”: “none”
“name”: “attr/type”
“name”: “config/on”
“parse”: {
“at”: “0x00f7”,
“idx”: “0x95”,
“read”: {
“fn”: “none”
“bindings”: [
“bind”: “unicast”,
“src.ep”: 1,
“dst.ep”: 1,
“cl”: “0x0006”,
“report”: [
“at”: “0x0000”,
“dt”: “0x10”,
“min”: 5,
“max”: 300
“bind”: “unicast”,
“src.ep”: 2,
“dst.ep”: 1,
“cl”: “0x0006”,
“report”: [
“at”: “0x0000”,
“dt”: “0x10”,
“min”: 5,
“max”: 300
Diiferences are minor to me : Your DDF have refresh.interval and default that are useless because they are the same than in generic item .json. And reference to xiaomi_swversion.js in swverion is missing, but that doesn’t interfere from my point of view with exitance of
