Hey there,
I have a super simple setup:
2 x Hue wall switches
2 x Hue bulbs
Now sometime it works and I can turn on/off the bulbs with the wall switch, sometimes it has a delay of multiple seconds, sometimes it just doesn‘t work.
One thing I noticed is that I have this log message „polluting“ the logs:
5:41:03:671 Force binding of attribute reporting for node wall switch buero
15:41:03:674 GW firmware version: 0x26690700
15:41:04:669 Idle timer triggered
15:41:04:671 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:04:672 Force binding of attribute reporting for node wall switch buero
15:41:05:668 Idle timer triggered
15:41:05:670 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:05:672 Force binding of attribute reporting for node wall switch buero
15:41:06:668 Idle timer triggered
15:41:06:670 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:06:672 Force binding of attribute reporting for node wall switch buero
15:41:07:668 Idle timer triggered
15:41:07:670 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:07:672 Force binding of attribute reporting for node wall switch buero
15:41:08:669 Daylight now: solarNoon, status: 170, daylight: 1, dark: 0
15:41:08:670 Idle timer triggered
15:41:08:672 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:08:673 Force binding of attribute reporting for node wall switch buero
15:41:09:668 Idle timer triggered
15:41:09:670 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:09:671 Force binding of attribute reporting for node wall switch buero
15:41:10:668 Idle timer triggered
15:41:10:672 Force read attributes for ZHASwitch SensorNode wall switch buero
15:41:10:674 Force binding of attribute reporting for node wall switch buero
15:41:11:668 Idle timer triggered
15:41:11:670 Force read attributes for ZHASwitch SensorNode wall switch buero
Here is a screenshot of my deconz setup:
I tried to google but couldn‘t find any helpful resources on what that means. Could somebody help me here?
- What does that log mean?
- Could it be the root issue of my delays and timeouts?
Thank you in advance for your help
