OK, will try 3-beta then.
Do you just want the same log detail as previously?
dpkg -l | grep -i deconz
ii deconz 2.12.03-raspbian-stretch-beta armhf A generic ZigBee monitoring and control tool
After start attempt: -
systemctl status deconz
● deconz.service - deCONZ: ZigBee gateway – REST API
Active: activating (auto-restart) (Result: signal) since Sat 2021-08-21 09:45:13 BST; 1s ago
Process: 17039 ExecStart=/usr/bin/deCONZ -platform minimal --http-port=80 (code=killed, signal=BUS)
Main PID: 17039 (code=killed, signal=BUS)
logs from journalctl: -
systemd[1]: deconz.service: Service RestartSec=30s expired, scheduling restart.
Aug 21 09:46:16 raspberrypi4 systemd[1]: deconz.service: Scheduled restart job, restart counter is at 5.
Aug 21 09:46:16 raspberrypi4 systemd[1]: Stopped deCONZ: ZigBee gateway – REST API.
Aug 21 09:46:16 raspberrypi4 systemd[1]: Started deCONZ: ZigBee gateway – REST API.
Aug 21 09:46:16 raspberrypi4 systemd[1]: deconz-init.service: Start request repeated too quickly.
Aug 21 09:46:16 raspberrypi4 systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Aug 21 09:46:16 raspberrypi4 systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Aug 21 09:46:16 raspberrypi4 deCONZ[17083]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-pi’
Aug 21 09:46:16 raspberrypi4 deCONZ[17083]: libpng warning: iCCP: known incorrect sRGB profile
Aug 21 09:46:17 raspberrypi4 deCONZ[17083]: This plugin does not support propagateSizeHints()
Aug 21 09:46:20 raspberrypi4 deCONZ[17083]: This plugin does not support propagateSizeHints()
Aug 21 09:46:20 raspberrypi4 systemd[1]: deconz.service: Main process exited, code=killed, status=7/BUS
Aug 21 09:46:20 raspberrypi4 systemd[1]: deconz.service: Failed with result ‘signal’.
Aug 21 09:46:20 raspberrypi4 systemd[1]: deconz-init.service: Start request repeated too quickly.
Aug 21 09:46:20 raspberrypi4 systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Aug 21 09:46:20 raspberrypi4 systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Manual start as previous: -
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-root’
Bus error
Just tried the above as a separate reply, and it stopped me, apparently I can only reply 3 times to one topic as I’m new.
Anything additional you need?
@rsedlmeier - Sorry, I don’t know what propagateSizeHints() means? I can’t reply any more - I’m blocked to x3 replies per topic.
Oddly 3-beta has started to work? I’ve changed nothing…
Aug 21 09:51:20 raspberrypi4 systemd[1]: Service RestartSec=30s expired, scheduling restart.
Aug 21 09:51:20 raspberrypi4 systemd[1]: deconz.service: Scheduled restart job, restart counter is at 14.
Aug 21 09:51:20 raspberrypi4 systemd[1]: deconz-init.service: Start request repeated too quickly.
Aug 21 09:51:20 raspberrypi4 systemd[1]: deconz-init.service: Failed with result ‘start-limit-hit’.
Aug 21 09:51:20 raspberrypi4 systemd[1]: Failed to start deCONZ: ZigBee gateway – Initialisation.
Aug 21 09:51:20 raspberrypi4 systemd[1]: Stopped deCONZ: ZigBee gateway – REST API.
Aug 21 09:51:20 raspberrypi4 systemd[1]: Started deCONZ: ZigBee gateway – REST API.
Aug 21 09:51:20 raspberrypi4 deCONZ[17658]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-pi’
Aug 21 09:51:20 raspberrypi4 deCONZ[17658]: libpng warning: iCCP: known incorrect sRGB profile
Aug 21 09:51:21 raspberrypi4 deCONZ[17658]: This plugin does not support propagateSizeHints()
Phoscon-GW Web Page hasn’t yet detected the ConBee II though!
Left it running a while and it still has not connected to the ConBee II. ~40mins
