Suddenly my deconz HA addon stops working after months/years.
I cant put my lights out (been on for +24 hours :() and i cant find the reason
I’m on latest HA version (rasp pi 4), deconz addon
In the logs from the addon i see
Tried rebooting/restarting/ unplugging… didnt add any new device/usb decvice
08:24:07:050 0x0017880104846CEF error APSDE-DATA.confirm: 0xE1 on task
08:24:07:854 0x0017880104A9F550 error APSDE-DATA.confirm: 0xA7 on task
08:24:08:734 0x00178801083CC172 error APSDE-DATA.confirm: 0xA7 on task
08:24:10:726 No presence sensor found for 0x001788010918AF04, endpoint: 0x02
08:24:10:727 ZCL attribute report 0x001788010918AF04 for cluster: 0x0406, ep: 0x02, frame control: 0x18, mfcode: 0x0000
08:24:10:729 SC tick → StateRead
08:24:10:730 SC tick → StateRead
08:24:10:735 0x842E14FFFEDFA22C error APSDE-DATA.confirm: 0xA7 on task
08:24:11:853 0x842E14FFFEDFA22C error APSDE-DATA.confirm: 0xA7 on task
Any idea what could cause this?
With the high energy prices, i would like to turn of my lights lol
Yes i check error codes, but couldnt find matching one
No phoscon doesnt control it properly
Deconz gui? → honestly i’m not used to use that app, i’m afraid to do something wrong there.
I also find out that one lamp does work 50/50
I explain:
I cant control the “dining lamp” using phoscon app/ nor using the HA dashboard where i have the light.diningroom added
BUT it does work using my input from my unipi board… controlling an mqtt switch, turning on that same light.
Very strange, i cant understand whats happening here
edit: went to see the logs but indeed i cant copy it, couldnt succeed yet with vnc to get it
I dont see an E1 failure…also if it is that one, i do use an extension cable, its not near usb device, its not near raspberry pi, and i already tried different channel (although it worked for years)
lol i overlooked that.
Anyway all the stuff there, is already taken care of
I use extension no near usb disk or antennes + i tried changing channel, nothing fixes
Any other idea?
I understand why you say i try to encourage people to fix themselves… but i dont see how
i also dont understand, why i can still use an mqtt switch to turn a light on/off but it doesnt work in deconz gui , nor does it work using ha dashboard (toggling light directly), it worked for years and nothing changed
