Since moving on the official deCONZ Desktop image for RaPi, I have a problem to connect the Homebridge/Hue Plugin and Homebridge/Deconz Plugin to REST API. I get an error “[deCONZ] warning: 0000000000000000: not a RaspBee/ConBee Mac address”
When using Hue Plugin by ebauuw, I get the message that the Conbee seems not to be correcty initialized.
Is this a known bug? I never had this before. Pressing the App-Link button doesn’t change it, also several reboots didn’t help.
As I had a Gateway on the same hardware before, this is still shown and greyed out. Is this the reason?
I can see the Gateway and it also shows the firmware of the Gateway - so it‘s connected. But the bridgeid remains to be all zeros.
With this Homebridge Hue has problems.
I use the DeCONZ Raspberry Pi image, which includes the GUI and also the headless services that run. I didn’t change anything and relied completely on the correctness of settings.
The issue also only is visible with the Homebridge Hue plugin and Homebridge DeCONZ plugin. But these ones are of course the most important ones.
When querying the REST API I can also see that bridgeid is report just with zeros.
I have tried the procedure in the link above, but without success. Even there I can see that the GUI deGONZ is not null for the MAC Address field, however, the log still shows the problem and the above error. I only see null entries there unless I quit the deconz running beforehand:
sudo systemctl stop deconz,
then the fields are null.
Is there any other procedure for this?
Would be interesting to see what the deCONZ GUI → Menu → Edit → Networks Settings look like.
It should look like the following with a valid MAC address:
