The described installation is not working in case that you want to use the new 64 bit Version of Raspberry Pi OS.
If you try to install wiringpi-latest.deb you get a error message which says that it needs libc6.
I installed libc6 via:
sudo apt install libc6-dev-armel-cross libc6-dev-armhf-cross
and installation was done.
On a seconed try (got some problems with other pakets and deceided to start at 0 again) I installed libc6 before I started to follow the instruction of DeConz installation.
This time I got the fault message the I need to repair libc6 by using
sudo apt --fix-broken install
I´m just wondering what caused that. The only difference was that I used
before I used
Tried it again and started again by 0 and got the same fault. If I install libc6 befor I install deconz I have to repair libc6 to install wiring-latest.
Am I doing something wrong? Is there a other way to install deconz on 64bit Raspberry OS?
