I updated six BlitzWolf Smart Socket BW-SHP15 devices using deCONZ v.2.33.1 beta via OTA. All six are now bricked; they no longer connect to the Zigbee network and don’t respond to the hardware button on the plug.
Has anyone else experienced this and perhaps found a solution?
Thanks and best regards
Herbi
Smanar
June 25, 2026, 3:38pm
2
This is not good …
I m searching on google, I don’t found more information, even after a power cycle you are not able the use the hardware button ?
Too late to see wich one firmware you are using or the device version ? or at least the model ?
"manufacturername": [
"_TZ3000_mraovvmm",
"_TZ3000_u5u4cakc"
the plugs are really dead. I tried some combinations of pressing the button and pluging in/out - no chance.
Unfortunately I deleted them in Phoscon yet, so I have no further informations.
Thank you very much !
Herbi
Smanar
June 26, 2026, 3:16pm
5
Nope, I mean I haven’t found similar issue on Google.
Firmaware are from here zigbee-OTA/images at master · Koenkk/zigbee-OTA · GitHub
And I don’t see the one for SHP15
Edit:
Ha there is perhaps an alternative firmware here zigbee-OTA/not-in-manifest-images/Telink at master · Koenkk/zigbee-OTA · GitHub
But I don’t see similar issue again …
Tank you very much!
The linked issue cocerns the TS011F / _TZ3000 _2putqrmw variant which still work fine for me.
I ment the newer TS011F / _TZ3210 _2putqrmw ones.
However, I sent them back and will try some Sonoff models.
Thanks and regards
Herbi
