Hi. I am having the exact same issue.
- DietPI (64bit), installed on a new SD card on Raspberry Pi 3 Model B Plus Rev 1.3
- 3 brand new
SNZB-02
sensors (never used, never paired)
- New ConBee III, updated to latest firmware.
- I am using Docker containers
Steps I did so far
- The container is booting up. -
e DECONZ_BAUDRATE=115200
is set.
- The Coordinator is recognized.
- Firmware update to
0x264E0900
was done.
SNZB-02
sensors are NOT fully recognized, neither via zigbee2mqtt
nor deconzcommunity/deconz:stable
- I also validated this on a Macbook with the native App.
- I tried to pair multiple times
In all cases, the initial handshake works but subsequent interviews failed.
Deconz 2.24.2 debug log per my discussion on discord: Ubuntu Pastebin
Deconz GUI on MacOS:
I can also confirm that with my old ConBee II and Zigbee2MQTT, the sensors connected on the first attempt w/o any issue.
So to me, it smells like a bug or incompatibility that can potentially be resolved with a software/firmware update.
Link to Discord thread: Discord
Update 2023-12-24
Today, I again tried to pair the SNZB-02 in my zigbee2mqtt container.
Here are the related logs:
Zigbee2MQTT:info 2023-12-24 07:41:28: Device '0x00124b002a5d2e2a' joined
Zigbee2MQTT:info 2023-12-24 07:41:28: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b002a5d2e2a","ieee_address":"0x00124b002a5d2e2a"},"type":"device_joined"}'
Zigbee2MQTT:info 2023-12-24 07:41:28: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x00124b002a5d2e2a"},"type":"device_connected"}'
Zigbee2MQTT:info 2023-12-24 07:41:28: Starting interview of '0x00124b002a5d2e2a'
Zigbee2MQTT:info 2023-12-24 07:41:28: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b002a5d2e2a","ieee_address":"0x00124b002a5d2e2a","status":"started"},"type":"device_interview"}'
Zigbee2MQTT:info 2023-12-24 07:41:28: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x00124b002a5d2e2a"},"type":"pairing"}'
Zigbee2MQTT:error 2023-12-24 07:47:28: Failed to interview '0x00124b002a5d2e2a', device has not successfully been paired
Zigbee2MQTT:info 2023-12-24 07:47:28: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00124b002a5d2e2a","ieee_address":"0x00124b002a5d2e2a","status":"failed"},"type":"device_interview"}'
Zigbee2MQTT:info 2023-12-24 07:47:28: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_failed","meta":{"friendly_name":"0x00124b002a5d2e2a"},"type":"pairing"}'
Update 2023-12-26
Out of curiosity, I today tried to pair a fresh TV02-Zigbee with the Conbee III using Zigbee2MQTT.
This worked flawless. So I see my base setup as confirmed to work OK.
