Hi all,
is there anyone using the deconz collector App for SPLUNK from FX Ganzer ?
I am struggling to get it working.
Tx
I haven’t heard about any of those things, ever
It’s not “very good” documented, but if it works, it could be a fine way to supervise the Zigbee network.
Or do you have other ways to supervise your sensors
Ah okay. I believe it’s just a tool to collect data into one database, correct?
Never seen it before so no clue how it works. I use home assistant myself
correct, if it works, it should log the status of all zigbee devices.
Then, an alert can be created if a sensor is unreachable …
I do not use HomeAssistant, I use openHAB.
Do you monitor the availability of your sensors with HomeAssistant and create alerts if one fails?
