DEconz can't connect to Conbee 2 Stick
My Deconz gui can’t connect to my running and operational Conbee 2 Stick.
Version: 2.11.05 / 19/08/2021
Firmware: 26660700
Deconz Version: 2.12.6
The stick is running perfectly on Homebridge (connected to raspi).
Are there any known issues or any advices on how to get the connection established?
09:16:13:310 device state timeout ignored in state 2
09:16:13:469 device state timeout ignored in state 2
09:16:13:630 device state timeout ignored in state 2
09:16:13:789 device state timeout ignored in state 2
09:16:13:950 device state timeout (handled)
09:16:14:030 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:16:14:031 device state timeout ignored in state 1
09:16:14:586 failed to reconnect to network try=8
09:16:14:587 wait reconnect 15 seconds
09:16:15:586 wait reconnect 14 seconds
09:16:16:586 wait reconnect 13 seconds
09:16:17:586 wait reconnect 12 seconds
09:16:18:586 wait reconnect 11 seconds
09:16:19:586 failed to reconnect to network try=9
09:16:19:587 wait reconnect 10 seconds
09:16:20:586 wait reconnect 9 seconds
09:16:21:586 wait reconnect 8 seconds
09:16:22:586 wait reconnect 7 seconds
09:16:23:586 wait reconnect 6 seconds
09:16:24:586 failed to reconnect to network try=10
09:16:24:587 wait reconnect 5 seconds
09:16:25:586 wait reconnect 4 seconds
09:16:26:586 wait reconnect 3 seconds
09:16:27:586 wait reconnect 2 seconds
09:16:28:586 wait reconnect 1 seconds
09:16:28:677 dev /dev/ttyS0 (/dev/ttyS0)
09:16:29:586 reconnect network failed, try later
09:16:29:587 wait reconnect 5 seconds
09:16:29:689 dev /dev/ttyS0 (/dev/ttyS0)
09:16:30:086 start reconnect to network
09:16:30:586 wait reconnect 4 seconds
09:16:31:586 wait reconnect 3 seconds
09:16:32:586 wait reconnect 2 seconds
09:16:33:586 wait reconnect 1 seconds
09:16:33:669 dev /dev/ttyS0 (/dev/ttyS0)
09:16:35:173 device state timeout ignored in state 2
09:16:35:334 device state timeout ignored in state 2
09:16:35:337 try to reconnect to network try=1
09:16:35:582 device state timeout ignored in state 2
09:16:35:742 device state timeout ignored in state 2
09:16:35:902 device state timeout ignored in state 2
09:16:36:062 device state timeout ignored in state 2
09:16:36:222 device state timeout ignored in state 2
09:16:36:382 device state timeout ignored in state 2
09:16:36:542 device state timeout ignored in state 2
09:16:36:702 device state timeout ignored in state 2
09:16:36:862 device state timeout ignored in state 2
09:16:37:022 device state timeout (handled)
09:16:37:102 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:16:37:103 device state timeout ignored in state 1
09:16:37:586 wait reconnect 15 seconds
09:16:38:586 wait reconnect 14 seconds
09:16:39:586 wait reconnect 13 seconds
09:16:40:586 failed to reconnect to network try=2
09:16:40:587 wait reconnect 12 seconds
09:16:41:587 wait reconnect 11 seconds
09:16:42:586 wait reconnect 10 seconds
09:16:43:586 wait reconnect 9 seconds
09:16:44:587 wait reconnect 8 seconds
09:16:45:586 failed to reconnect to network try=3
09:16:45:586 wait reconnect 7 seconds
09:16:46:586 wait reconnect 6 seconds
09:16:47:586 wait reconnect 5 seconds
09:16:48:586 wait reconnect 4 seconds
09:16:49:586 wait reconnect 3 seconds
09:16:50:586 failed to reconnect to network try=4
09:16:50:587 wait reconnect 2 seconds
09:16:51:587 wait reconnect 1 seconds
09:16:51:632 dev /dev/ttyS0 (/dev/ttyS0)
09:16:52:586 wait reconnect 5 seconds
09:16:52:632 dev /dev/ttyS0 (/dev/ttyS0)
09:16:53:586 wait reconnect 4 seconds
09:16:54:586 wait reconnect 3 seconds
09:16:55:586 failed to reconnect to network try=5
09:16:55:587 wait reconnect 2 seconds
09:16:56:586 wait reconnect 1 seconds
09:16:56:632 dev /dev/ttyS0 (/dev/ttyS0)
09:16:56:692 dev /dev/ttyS0 (/dev/ttyS0)
09:16:58:166 device state timeout ignored in state 2
09:16:58:326 device state timeout ignored in state 2
09:16:58:486 device state timeout ignored in state 2
09:16:58:646 device state timeout ignored in state 2
09:16:58:806 device state timeout ignored in state 2
09:16:58:967 device state timeout ignored in state 2
09:16:59:126 device state timeout ignored in state 2
09:16:59:286 device state timeout ignored in state 2
09:16:59:446 device state timeout ignored in state 2
09:16:59:606 device state timeout ignored in state 2
09:16:59:766 device state timeout ignored in state 2
09:16:59:926 device state timeout (handled)
09:17:00:006 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
09:17:00:007 device state timeout ignored in state 1
09:17:00:586 failed to reconnect to network try=6
09:17:00:587 wait reconnect 15 seconds
09:17:01:586 wait reconnect 14 seconds
09:17:02:586 wait reconnect 13 seconds
09:17:03:586 wait reconnect 12 seconds
09:17:04:586 wait reconnect 11 seconds
09:17:05:586 failed to reconnect to network try=7
09:17:05:587 wait reconnect 10 seconds
and
09:17:21:486 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
09:17:21:646 void zmMaster::handleStateStatus(zmMaster::MasterEvent) EVENT_TIMEOUT
Do you have deconz running at the same time (already?)
Deconz and deconz-gui are doing the same, but the latter has the gui. You can’t run them both at the same time.
If you stop deconz and start deconz-gui, you can see it works :slight_smile:
Yeah…That was the solution :slight_smile:
Thank you very much!
