Hi I have a deconz 2 stick that I want to connect to OpenHAB. Phoscon is installed but does not connect to the stick.
Extension cable is attached and the installing is on a Rasbian Openhab system.
I added the beta repository for phoscon. Installing of phoscon worked like a charm.
Now I get the following output when searching for the device.
—- snip —-
openhabian@CarBee:~ $ GCFFlasher_internal -l
openhabian@CarBee:~ $ lsusb
Bus 001 Device 003: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
—- snip —-
Anybody has a clue why the stick is detected by lsusb correctly but not by GCF and then also not by Phoscon (Firmware: not connected)?
Any help appreciated! Thank you in advance!
