Can I insert the zll.db und deCONZ.conf file from Debian into a new image in Home Assistant so that all sensors are in the system and I can continue using Phoscon?
For the zll.bd file, yes it’s the complete database.
For deCONZ.conf not, this is the network config, but it’s saved on the gateway, so if you use same gateway, no need.
And the OS on HA is using docker, hard to use.
