DDF help: Shelly BLU TRV (SBTR-001AEU)
I would like to get the Shelly BLU TRV (SBTR-001AEU) working properly with deCONZ. I have very little experience with creating DDFs myself, so I would appreciate help with this or an existing DDF if someone has already worked on this device.
I have successfully joined the TRV to my deCONZ Zigbee network using a ConBee coordinator. Phoscon reports “Connection failed” during the pairing process, but the device actually appears in the deCONZ GUI and seems to have joined the network successfully.
deCONZ identifies endpoint 0x01 as a Home Automation / Thermostat device.
The clusters visible on endpoint 0x01 include:
  • 0x0000 Basic
  • 0x0001 Power Configuration
  • 0x0003 Identify
  • 0x0004 Groups
  • 0x0005 Scenes
  • 0x0201 Thermostat
  • 0x0402 Temperature Measurement
  • 0x0406 Occupancy Sensing
  • 0xFC24 manufacturer-specific / Unknown
The standard Thermostat cluster 0x0201 is populated and readable. For example, I can see:
  • Local Temperature
  • Occupied Heating Setpoint
  • Min/Max Heating Setpoint
  • PI Heating Demand (0x0008)
The PI Heating Demand (0x0008) attribute is present as uint8, but deCONZ shows it as read-only.
This last point is particularly interesting because Shelly documents the BLU TRV as supporting two operating modes: normal temperature-based TRV control and manual valve control (%).
My main goal is therefore not only normal thermostat operation in Home Assistant, but preferably also access to the current valve position and direct 0–100% valve control. I am considering using the TRV as an actuator controlled by Home Assistant with an external room temperature sensor.
Cluster 0xFC24 is also shown by deCONZ, but its attribute list appears empty in the deCONZ GUI.
Interestingly, the same device is simultaneously discovered by Home Assistant over BTHome/Bluetooth. BTHome currently exposes temperatures, battery, RSSI and packet ID, but not the active valve control functionality.
Could someone help me create a proper DDF for this device, or point me to an existing one?
I can provide screenshots from deCONZ, Node Descriptor information, cluster/attribute information or any other diagnostics needed. The TRV is currently paired to my deCONZ network, so I can test a DDF or collect additional information from the device.
In particular, I would be very interested to find out whether Shelly’s manual valve control (%) is exposed through Zigbee, possibly through the manufacturer-specific 0xFC24 cluster.
Thanks in advance for any help!
I m seing a “position” in
Cluster 0xfc24
Attribute 0x0001
Data type uint8
But IDK if this attribute is read and write.
Can be usefull to add this cluster to deconz to make test.
Do you know how to edit the general.xml file to add thoses fields ?
Thanks Smanar!
Yes, cluster 0xFC24 is visible on endpoint 0x01 in my deCONZ GUI, but it is shown as Unknown and the attribute list is just completely empty.
I have not edited general.xml before, but I can make a backup and test a definition for attribute 0x0001 as uint8 if you can help me with the correct XML entry and location. Perhaps I need also help from the AI, I understand it is frustrating to talk with a novice..
The device is currently paired and working via bluetooth (HAOS integration GitHub - reinhard-brandstaedter/hass_shelly_blu_trv: Home Assistant custom integration for Shelly BLU TRV (Bluetooth thermostatic radiator valve) · GitHub), so I can test whether the attribute is readable and whether deCONZ reports it as writable.
make a search in file /usr/share/deCONZ/zcl/general.xml on <!-- Shelly --> you will found a cluster bloc for this manufacture
Try to add this code INSIDE the tag <domain>, and I presume the manufacture code is still 0x1490 ?
    <cluster id="0xfc24" name="Shelly TRV Cluster" mfcode="0x1490">
      <description>Used by shelly TRV.</description>
      <server>
        <attribute id="0x0000" name="Manual mode" type="u8" mfcode="0x1490" access="rw" required="o"></attribute>
        <attribute id="0x0001" name="Valve position" type="u8" mfcode="0x1490" access="rw" required="o"></attribute>
      </server>
      <client>
      </client>
    </cluster>
Value for position from 0 to 100, vaue for manual mode 0 = auto 1 = manual.
Then restart deconz after change, you will see them on the cluster after it.
Thanks a lot for looking into this and for the instructions! Sounds promising.
I’m running HA OS, where deCONZ is running in its own container, so I don’t have direct access to /usr/share/deCONZ/zcl/general.xml from the normal HA terminal. I’ll need some time to figure out how to access and modify it.
If anyone else gets a chance to test this with the Shelly BLU TRV, please report the results here as well.
IDK how it work on HA, but from my memory you have acces to the GUI ?
It’s possible to load partial xml using deconz/edit/preference.
Perhpas this link can help you to find the shared folder ? How to add/edit a DDF on Home assistant using text editor?
