DDF for Aubess Tuya Smart ZigBee Temperature and Humidity Sensor
I created a DDF for this device - works flawlessly for some weeks now.
I would create a PR for this - any preference where to store, should I create a new folder “Aubess” or put in “tuya”?
  "manufacturername": "_TZ3000_bguser20",
  "modelid": "TS0201",
  "vendor": "Aubess",
  "product": "TS0201",
  "sleeper": false,
  "status": "Gold",
  "path": "/devices/Aubess_temp_hum_sensor_ts0201.json",
      "restapi": "/sensors",
        "0x01",
        "0x0402"
          "name": "attr/swversion"
          "name": "config/battery",
          "awake": true,
          "refresh.interval": 3600,
          "read": {
            "at": "0x0021",
            "cl": "0x0001",
            "fn": "zcl"
            "at": "0x0021",
            "cl": "0x0001",
            "fn": "zcl"
          "default": 0
          "name": "config/offset",
          "description": "Relative offset to the main measured value.",
          "default": 0
          "name": "config/on"
          "name": "config/reachable"
          "name": "state/lastupdated"
          "name": "state/temperature",
          "default": 0
        "0x01",
        "0x0405"
          "awake": true,
          "read": {
            "at": "0x0021",
            "cl": "0x0001",
            "fn": "zcl"
            "at": "0x0021",
            "cl": "0x0001",
            "eval": "Item.val = Attr.val / 2",
            "fn": "zcl"
          "default": 0
          "default": 0
          "name": "config/on"
          "name": "state/humidity",
          "default": 0
  "bindings": [
      "cl": "0x0001",
          "at": "0x0021",
          "dt": "0x20",
          "min": 60,
          "max": 3600,
          "change": "0x00000001"
      "cl": "0x0402",
          "at": "0x0000",
          "dt": "0x29",
          "min": 60,
          "max": 300,
          "change": "0x00000064"
      "cl": "0x0405",
          "at": "0x0000",
          "dt": "0x21",
          "min": 60,
          "max": 300,
Thx for that ^^.
It’s like you want, but there is too much “no name” tuya, so yes for me better to create a “aubess” folder.
Just a comment, you can remove from your DDF, the line “path” and all lines “description”
Great. But how do I uplaoad that to the DECONZ integration running on my Home Assistant Operating System (intel NUC - not a Container installation). Only limited Terminal experience therefore will need clear and simple step by step instructions and guide! Thanks
Perhaps How to add/edit a DDF on Home assistant using text editor?
Thank you. Yes I already had seen this. But how do I get the new DDF file uploaded in the first place ?
Here you have 2 ways, the text editor, used with copy/paste or the “docker cp” to copy files.
One time the file is created, you just need to restart deconz and re-include the device.
